Substitution for the bottom retainer
Old Mar 13, 2003 | 02:06 PM
Anthonyl469's Avatar
Default Substitution for the bottom retainer
OK I took my head to the machine shop today...and they lost the bottom retainer to one of the vavle springs...They want me to put a washer on there and are saying it will be ok....Will this work?
Old Mar 13, 2003 | 02:10 PM
BabyDaddy's Avatar
Default Re: Substitution for the bottom retainer (Anthonyl469)
and they lost
Nuff said. If it were mine, they would fix it with factory parts or walk with a severe limp for the rest of their life. If they are any kind of shop then they will correct one of their own mistakes at their own expense. I do.
[Modified by BabyDaddy, 11:11 PM 3/13/2003]
Old Mar 13, 2003 | 02:38 PM
Default Re: Substitution for the bottom retainer (BabyDaddy)
thats not the problems...its that I have to have the car in a show Saturday...
Old Mar 13, 2003 | 02:58 PM
BabyDaddy's Avatar
Well to directly answer your question then...
I don't know if the part your talking about is heat-treated in any way or not. You may get lucky and a washer may do a fine job of it. I'm fixing to go to a friend of mine's that has a degree in metalurgy. Maybe he can shed some light on the subject. At the very minimum, I would make the dimensions (od, id, and thickness) match the factory part.
But another serious question to you...
Is that one show more important to you than rebuilding your motor?
Old Mar 13, 2003 | 02:59 PM
MikeMAN's Avatar
nevermind, forgot its an ITR engine
mike
[Modified by MikeMAN, 6:00 PM 3/13/2003]
Old Mar 13, 2003 | 04:19 PM
Jared's Avatar
washer wont work, changes the valve spring installed height too much, you need that bottom spring seat, otherwise you're fucked.
Old Mar 13, 2003 | 04:56 PM
HEAD's Avatar
Default Re: Substitution for the bottom retainer (Jared)
I will second that because not only does that help get the installed height right, it also centers the I.D. of the spring, I'm sure you could get it from the dealer and they would have it in stock, I think I have one to I could give to you. My serious advice is 1don't worry about a show and half *** put your car together because you might be towing it there anyway trying 2 If a pro machine shop told you a "washer"would be a good sub for a shim I would NEVER go there or talk to them again even if something went wrong with the stuff they did for you because they have just shown they don't know there *** from a hole in the ground, I don't know what all they did I say screw the show get there work checked by a more knowledgeable shop and fix it right. Good Luck!!!
Quad-Damag
Audio / Security / Video
Sep 4, 2003 12:18 PM
Jonathan_ED3
Jul 19, 2003 11:21 PM
its WANG yoO
Feb 18, 2003 06:14 AM
Speedfreak
Jan 28, 2003 06:04 PM
