Does the ECU affect the speedo/odometer ?
Old Mar 12, 2003 | 11:26 PM
Pat's Avatar
Pat
Default Does the ECU affect the speedo/odometer ?
Maybe a weird question, but I drive a Canadian model but I'll be putting a p75 from a USDM model. Will this make a difference or are both ecus the same? I read that they had slightly different part numbers, but I'm not sure if that means they are different. TIA
oh yeah , my concern is with the kilometers/miles measurement differences.
[Modified by Pat, 1:23 AM 3/13/2003]
Old Mar 13, 2003 | 05:05 AM
b19coupe's Avatar
Default Re: Does the ECU affect the speedo/odometer ? (Pat)
It will not affect your speedo. The signal from the speed sensor goes directly to the instrument cluster, with no input from the ECU. The ECU also receives a signal from the speed sensor, to help determine operating parameters, but that has no affect on your speedo.
Old Mar 13, 2003 | 01:31 PM
Pat's Avatar
Pat
Default Re: Does the ECU affect the speedo/odometer ? (b19coupe)
awesome, that's what I wanted to hear. Thanks
draggbody
Engine Management and Tuning
Aug 14, 2012 04:45 AM
msedacca
Jun 9, 2008 08:51 AM
stunnerone23
Sep 2, 2005 06:26 PM
Kataku2K3
Nov 6, 2002 02:22 PM
