jumping service connector in integras. (to get ECU code)
Old Mar 14, 2003 | 11:26 AM
baonest1's Avatar
Default jumping service connector in integras. (to get ECU code)
curious on where the wire leads to. i wanna see if i have a short in the wire somwhere.. cuz i have a check engine light, no flash, just constant light. i doubt its ECU failure. so i just wanna see where the wire leads to so check to see if its damaged. there is a black and brown wire. im guessing the black is ground??
Old Mar 14, 2003 | 11:53 AM
Spade's Avatar
Default Re: jumping service connector in integras. (baonest)
So when you jump it and turn the engine on the light stays constant?
That means bad ECU I hope not.
Old Mar 14, 2003 | 12:01 PM
baonest1's Avatar
Default Re: jumping service connector in integras. (Spade)
yah man.. stays constant.
but the car turns on. like normal. hmmmm maybe its a bad chip??
Old Mar 14, 2003 | 12:24 PM
BluntMan's Avatar
so you jumped it first right? cuz ive never seen that before. and after you jump it it still stays on constant? try starting the car and then jumping it.
Old Mar 14, 2003 | 01:09 PM
baonest1's Avatar
Default Re: jumping service connector in integras. (BluntMan)
yah. ive tried all that. different ways of jumping it. just a constant light.
Old Mar 18, 2003 | 09:48 AM
JimBlake's Avatar
Maybe this is what you want???
The black wire goes to ground.
The brown/white-stripe wire goes to pin D4 on the ECU.
So if your wiring is screwed up, you can ground pin D4 on the ECU harness to do the same thing.
JDMlyfestyle
18
Apr 29, 2021 01:09 AM
RudyCholo
Jan 25, 2006 04:35 PM
yellowjdmcrx
17
Nov 21, 2005 02:57 AM
yoshio006
May 22, 2005 06:49 PM
LudeBehavior
Oct 2, 2002 08:49 AM
