my engine is acting weird, help!!!
Old Mar 12, 2003 | 07:33 PM
kHoA DoGG's Avatar
Default my engine is acting weird, help!!!
This started when I removed my stereo harness that had MSD2step hooked up to it. As of now, the car will go up to 5k rpms then drop power as if no spark is getting through and the car will turn off. The check engine light and Ebrake light will flash then turn off.I double check my VAFC, MSD 6AL/cap/blaster2/2step wiring and it's all legit. I'm running a JDM B16A w/ a chipped PM6 ecu. Could it be a dead coil? Dead plugs? Low battery? Dead 6AL box? Dead ECU? HELP!!!! I have to drive 400mls next week to get home!!!
Old Mar 12, 2003 | 07:36 PM
Spade's Avatar
Default Re: my engine is acting weird, help!!! (sNoOziN' EF8)
Do you have exposed wires from the harness? Or are they all cut flush?
Old Mar 12, 2003 | 07:40 PM
IEATLINT's Avatar
Default Re: my engine is acting weird, help!!! (Spade)
are you grounding something out behind the dash???.... i don't know thats the first thing that came to my head, good luck!
-Devin-
[Modified by IEATLINT, 4:41 AM 3/13/2003]
Old Mar 12, 2003 | 07:57 PM
kHoA DoGG's Avatar
Default Re: my engine is acting weird, help!!! (IEATLINT)
That's what I thought too, but I will triple check. Feels like the tach sensor is grounding out somewhere but can't find where.
Old Mar 12, 2003 | 10:17 PM
kHoA DoGG's Avatar
anybody else?
Old Mar 13, 2003 | 10:47 AM
Spade's Avatar
Have you checked the wires yet?
Old Mar 13, 2003 | 12:10 PM
kHoA DoGG's Avatar
nothing is grounding.
Old Mar 13, 2003 | 12:16 PM
Spade's Avatar
All fuses are good?
All MSD connections are tight?
No codes?
Plugs look okay?
Old Mar 13, 2003 | 05:10 PM
kHoA DoGG's Avatar
okay i got it, it was my intake air temp. sensor module. damn crimpers, gotta get a soldering iron.
tempsohc
Jul 4, 2016 08:30 AM
thienpham
May 14, 2009 06:54 PM
turbocivic7901
Dec 2, 2006 10:15 AM
DarkDragon
Dec 18, 2005 11:05 AM
RotiEatter
Aug 15, 2005 09:34 AM
