o2 sensor...rewiring..
Old Mar 11, 2003 | 07:26 PM
civic_dreams95's Avatar
Default o2 sensor...rewiring..
how can i make the 1 wire o2 sensor work on my 5 wire harness?
Old Mar 11, 2003 | 10:36 PM
Usdm1's Avatar
Default Re: o2 sensor...rewiring.. (civic_dreams95)
What are you doing ?? swaping the engine ??
are you using the same VX Ecu ? if so you dun need to swap to a single wire o2..
If your doing a swap that has a single wire o2 and your using the single o2 Ecu then all you do is wire the single o2 to the ecu ... check hasport.com to find which ecu pinout you need to wire the single wire too ...
GL
Old Mar 11, 2003 | 11:08 PM
Ekasey's Avatar
Default Re: o2 sensor...rewiring.. (Usdm1)
well if you are trying to go from a 4 wire (heated o2 sensor) to a single (non heated) it's just not gonna work unelss your chnaging to the proper ecu for that o2. the difference is one is heated one is not a single wire will not work with a 4 wire harness you need to go buy an o2 sensor
jdmhonda25
Jan 3, 2014 10:03 AM
BoogiepopJDM
Jun 17, 2006 09:26 PM
5STAR3
Mar 24, 2004 09:09 AM
H23vtecEG
Apr 4, 2003 08:12 AM
