shaving flywheel
Old Mar 11, 2003 | 12:57 PM
NightHawkC5's Avatar
Default shaving flywheel
what kind of a shop do i send my flywheel to lose a few pounds and around how much does it go for and is there one around me
[Modified by NightHawkC5, 9:59 PM 3/11/2003]
Old Mar 11, 2003 | 05:02 PM
genetsang's Avatar
Default Re: shaving flywheel (NightHawkC5)
you are better off getting only thats already lightened... the new aftermarket one will probably going to cost you as much as.. lightening away a stock one......
Old Mar 11, 2003 | 05:06 PM
BabyDaddy's Avatar
Take it to a machine shop or someone who has a brake rotor lathe big enough to handle the flywheel and let'em go to work on it. You can get about 3-4 pound off of the stock one without running into problems. They should charge you about $80-140.
Old Mar 11, 2003 | 05:09 PM
Colin's Avatar
getting your stock one lightened is going to be a LOT cheaper than getting an aftermarket one. although an aftermarket one will be lighter. Expect to pay $300-$400 for an aftermarket flywheel. And expect to pay no more than $160 to have your stock one lightened, balanced and resurfaced. Just don't take too much weight off of it. After its down to about 12lbs the strength is questionable.
Old Mar 11, 2003 | 07:51 PM
genetsang's Avatar
Default Re: shaving flywheel (91IntegGS)
sorry.. but for my opion.. $300+?? where are you pulling these prices out of.... he is not asking for a full blown flywheel... im sure hes asking for a decent 12-15 lbs one.. and for that weight.. it will definetly not going to cost him 300-500
for 300-500... you are comparing it to toda, spoon, fidanza,
but for 150-200... you can easily find one from act and companys like that..
i got from act and i didnt spend 200+ for it.
thats my thought in it.....
Old Mar 11, 2003 | 08:25 PM
turbod92hatch's Avatar
Default Re: shaving flywheel (genetsang)
what flywheel did you go with and where did you get it, i was thinking about lighting a stock on too but that price sounds better to me. i can get the jun for 290 but want to see my options
Old Mar 11, 2003 | 08:40 PM
TimoneX's Avatar
New User
Fidanza $285. 7.2ish pounds.
Old Mar 11, 2003 | 08:59 PM
Default Re: shaving flywheel (TimoneX)
the jun is 9 lbs, where did you find it at
Old Mar 12, 2003 | 07:58 AM
92SiB18C1's Avatar
Default Re: shaving flywheel (turbod92hatch)
Ok stupid question.
Let's say I have 12 lbs flywheel in my car. How does it feel compare to 8 lbs flywheel? What's best for street driver with occasional drag race?
Old Mar 12, 2003 | 08:10 AM
genetsang's Avatar
Default Re: shaving flywheel (92SiB18C1)
the best bet is to go 12 lbs.... its much lighter then stock and you wont have to worry about having a horrible low end... rough ride and ****..... but ppl been going 8 lbs... but no complaints from them... so i guess its up to preference and your setup
whitehf
Feb 4, 2006 05:20 AM
delslo93
Feb 22, 2005 05:43 PM
killerboots
Apr 29, 2003 08:35 AM
CRXSleeper
15
Jul 3, 2002 09:16 PM
B_CRUZ!
Jan 18, 2002 06:43 PM
