Sensor near crank pulley on B18B1
Old Mar 12, 2003 | 01:18 PM
rotten's Avatar
Default Sensor near crank pulley on B18B1
I'm not able to find in the helms what the sensor on the B18B1, that is down by the crank pulley. I thought it was a crank angle sensor, but that is part of the Distributor (B16A1 head). Anyone have any ideas?
-k
Old Mar 12, 2003 | 02:28 PM
kyle h.'s Avatar
Default Re: Sensor near crank pulley on B18B1 (rotten)
is it on the same side as the pulley or the back side of the motor?
Old Mar 12, 2003 | 02:31 PM
Chiovnidca's Avatar
-k
Crank speed fluctuation sensor maybe?
sgT's Avatar
sgT
96+ will have a crankshaft fluctuation sensor on the crank timing belt gear.
Old Mar 12, 2003 | 06:37 PM
rotten's Avatar
Default Re: Sensor near crank pulley on B18B1 (sgT)
Yeah that is probably it. Its out of a 1996 Integra LS, but my documents don't mention a crankshaft fluctuation sensor, so I'm assuming its optional when using an ODB0 B16A head/harness/ecu.
Old Mar 12, 2003 | 06:55 PM
Chiovnidca's Avatar
It's used on some OBD2 cars. It's sensitive enough for the ECU to determine a single cylinder missfire. (Along with input from the o2 sensor.)
Old Mar 12, 2003 | 07:00 PM
liquid51's Avatar
Default Re: Sensor near crank pulley on B18B1 (D16Chiovnidca)
Isn't that a tdc sensor? or crank position sensor? I guess were talking about the same thing; crank fluctuation sensor.
Old Mar 12, 2003 | 08:01 PM
Chiovnidca's Avatar
Default Re: Sensor near crank pulley on B18B1 (liquid51)
Isn't that a tdc sensor? or crank position sensor? crank fluctuation sensor.
Those are three seperate sensors.
Old Sep 25, 2005 | 04:32 PM
DelSolDon's Avatar
Default Re: Sensor near crank pulley on B18B1 (Chiovnidca)
bump from the dead cause i found the same sensor on a '97 D16Y8 that i just pulled from a buddy's car. i am planning on swapping in an OBD1 D15B1 which does not have the same sensor. will not running this sensor while using the OBD2 ECU make it run in limp mode or just throw a CEL?
*before anyone asks* my buddy seized up the Y8 by running it with little or no oil and he just wanted a cheap replacement to get it running again. i considered swapping over the oil pump from the Y8 (with the sensor), but I'm afraid that the pump isn't in the greatest condition.
Old Sep 25, 2005 | 06:09 PM
mmuller's Avatar
Mad Scientist
Default Re: Sensor near crank pulley on B18B1 (DelSolDon)
you dont need to add the sensor; you can just wire the ckf to the ckp.
Old Sep 25, 2005 | 06:18 PM
DelSolDon's Avatar
Default Re: Sensor near crank pulley on B18B1 (mmuller)
thanks, i'm assuming that the D15B1 has the crank position sensor? you don't happen to know where the CKP is on the engine, do you? the CKF i know is a 2-wire sensor, is the CKP a 2-wire sensor also? just check with a multi-meter to see which wire to splice to which wire?
Natie Barnard
Honda CR-V & Element
Jan 16, 2019 06:38 AM
kndj30
Honda Civic (2001 - 2005)
Feb 11, 2010 03:58 AM
xwhitchx
May 27, 2009 05:55 PM
kaddi88
Aug 25, 2008 05:14 PM
pinota
Jan 8, 2003 11:18 AM
