Driver's with P28 ECU's
Old Mar 13, 2003 | 08:35 PM
Roger's Avatar
Default Driver's with P28 ECU's
How often should I get my programmed P28 ecu checked and calibrated ? The reason why I ask this is because recently, I ran over some railroad tracks that really jolted my car; and I noticed that the ECU was acting up. You know, miss firing and hesitation when I pressed the gas pedal. But when I turned off the car, everything was fine and smooth. Today, it did the same thing but it happened when I was powershifting getting onto the freeway. has anybody experienced this before ? Thx in advance guys.
[Modified by Roger, 5:36 AM 3/14/2003]
Old Mar 14, 2003 | 12:22 AM
Jackson's Avatar
Default Re: Driver's with P28 ECU's (Roger)
You might have some loose connections or maybe even a loose battery. Does your car have the stock battery tie-down?
Old Mar 14, 2003 | 06:15 AM
eg6ajk's Avatar
check all the electrical . ie distributor for loose wires or plugs first then if all is fine in the engine bay. if that fails, try switching to another ecu see if the problem occurs
blackcivic11
17
Jul 24, 2009 01:32 PM
kentuckyhatch
Engine Management and Tuning
Jun 30, 2009 10:05 AM
Woogie Ctr
Apr 20, 2006 06:07 AM
Guru Designs
Dec 29, 2005 01:11 AM
Guru Designs
Dec 28, 2005 09:33 PM
