Gasket?
Old Mar 11, 2003 | 02:31 PM
tolowhb's Avatar
Default Gasket?
Heres the problem. I have 93 civic dx coupe which I bought during the summer and drove from mass upto vermont (about 200 miles) the car ran perfect, very quiet many times I couldnt even tell it was still running. So anyways I look under the hood and it looked like next to the motor on the motor splash shield under where the ac comressor would be mounted there was what looked like some oil, it was there when I bought it. Well I wiped it off and let the car run for about 30minutes and no "oil" came back, but I looked near the timing belt cover on the front side of the motor near the head and it looked like there was a tiny bit of oil leaking but hardly anything. The car runs perfect it has 139,000 miles on the ticker and seems to run perfect. Now the car hasnt run for awhile this winter so I dont know if the cold could affect the gasket size making it leak a bit. It has perfect compression on all four cylinders. Well anyways should I be conserned about the "problems"?
Old Mar 11, 2003 | 03:14 PM
tolowhb's Avatar
Default Re: Gasket? (tolowhb)
Bump
Old Mar 11, 2003 | 03:21 PM
BangAccord's Avatar
have somebody check it out...it only costs about 20 bucks and it's usually worth the piece of mind
Old Mar 11, 2003 | 06:37 PM
tolowhb's Avatar
Default Re: Gasket? (BangAccord)
True.
93grayeg
Sep 24, 2018 03:46 PM
VTECwalka
Oct 30, 2012 06:02 AM
Coomer
Aug 20, 2008 08:23 AM
JdmGizmo
11
Feb 16, 2008 09:32 PM
tolowhb
Mar 11, 2003 06:38 PM
