Vibration after h22 swap.
Old Jan 27, 2004 | 08:24 PM
matix's Avatar
Default Vibration after h22 swap.
Ok i narrowed it down to the drivers side axle. When i got my swap they used my accord axles and shaft with the h22 tranny. I have noticed when i hit a bump i feel a vibration from the divers side axle. I jacked my car up and noticed the hub (or clyinder looking thing with rubber boot on it) was moving left and right. So i slid it to the right and it seemed to click in. Then i thought hmm maybe they just didnt click it in. I go driving feels fine for about 5 min. Then vibration starts occuring again. Look again and this hub thing moved to the left again. What could be causing this maybe they froggot to tighten something inside the boot. PLease help im not to good with axles and could use all your help. From what i have read this is not supposed to move left and right. My passenger side doesnt move at all.
Old Jan 27, 2004 | 10:24 PM
boostn420's Avatar
Default Re: Vibration after h22 swap. (matix)
It sounds like they left an axle nut loose/off. Is it on the outboard side (wheel) or inboard that you are able to move it.
Old Jan 28, 2004 | 08:37 AM
matix's Avatar
its the one nearest to the tranny. I just found grease slung everywere
Old Feb 1, 2004 | 12:47 AM
afterburners's Avatar
Default Re: (matix)
your axles seems to be to short maybe.
Old Feb 1, 2004 | 07:15 AM
evilhatch2.0's Avatar
maybe the axle somehow got crooked, maybe when they swapped the motor somebody ran it over in the middle of the axle?
H22 coupe
Jan 10, 2008 09:28 PM
jdmegh
May 25, 2007 07:21 AM
95accordh22a
Jan 10, 2006 07:15 PM
