oil pan gasket help
Old Jan 30, 2004 | 04:58 AM
htownteg's Avatar
Default oil pan gasket help
does anyone know what side the oil pan gasket is supposed to go on...is it flat surface against the block and fins against the oil pan?
anyone think oil pan gasket brand matters..i.e. felpro(autozone) or oem honda?
and are you supposed to not run the car after installing the oil pan gasket? someone told me that just want to get some suggestions
thanks
Old Jan 30, 2004 | 07:36 AM
integra6650's Avatar
Default Re: oil pan gasket help (htownteg)
there should be a groove on the oil pan so fins go down
Old Jan 30, 2004 | 05:28 PM
htownteg's Avatar
bump! anyone else?
Old Jan 30, 2004 | 06:39 PM
Jokerluv's Avatar
use OEM, and use hondabond HT to help keep it in place
Old Jan 30, 2004 | 07:15 PM
boostn420's Avatar
Default Re: (Jokerluv)
There is a specific pattern to it so it only goes on one way. It doesnt really matter whos gasket you use but the torque spec is important. If its too tight the oil pan will slightly warp between the bolts causing it to seep oil slowly. If that happens, just loosen them and retorque.
somick
Aug 3, 2017 08:45 AM
Romodavid15
Mar 16, 2010 08:16 AM
phelpsj2
Mar 9, 2010 12:16 PM
bopbop93030
Jul 20, 2009 08:41 AM
deconstruct
Jun 18, 2004 01:00 PM
