Tranny grinding.. Quick fixes??
Old Jan 30, 2004 | 11:17 AM
tgreaves's Avatar
Default Tranny grinding.. Quick fixes??
I have a 89 crx dx tranny and it grinds a little when going into 2nd gear.. I could give a **** less about the trans but its too damn cold here to change it right now.. Will putting a different fluid help it not to grind as much.. I have heard redline oil will help a grinding tranny but I have never tested this.. Anyone have an idea for me.. Thanks
Old Jan 30, 2004 | 11:39 AM
Kendall's Avatar
Go to the nearest Chevy dealership and get three quarts of GM Synchromesh Friction Modified. It solved my problem.
Old Jan 30, 2004 | 11:52 AM
mike1114's Avatar
Default Re: (Kendall)
won't solve everyone's problem though. Did nothing for me but worth a try.
If you still grind you need tranny rebuild, synchro fucked.
or buy new tranny.
Old Jan 30, 2004 | 12:16 PM
tgreaves's Avatar
Ill try the gm fluid.. When it gets warm out im going to buy a crx si tranny so that will solve the problem.. Thanks for the input..
Old Jan 30, 2004 | 02:33 PM
SOHKis's Avatar
Default Re: (tgreaves)
how many quarts in a gsr tranny?
Old Jan 30, 2004 | 02:46 PM
JimBlake's Avatar
Default Re: (SOHKeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHKeg &raquo;</TD></TR><TR><TD CLASS="quote">how many quarts in a gsr tranny?</TD></TR></TABLE>A bit less than 2 & 1/2 depending on how thoroughly you drain it.
Old Feb 2, 2004 | 05:52 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Go to the nearest Chevy dealership and get three quarts of GM Synchromesh Friction Modified. It solved my problem.</TD></TR></TABLE>
Why do I need 3 quarts.. My tranny only holds I think 1.9 quarts??
Old Feb 2, 2004 | 06:53 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Why do I need 3 quarts.. My tranny only holds I think 1.9 quarts??</TD></TR></TABLE>Maybe he thought ALL Honda trannies hold 2.5 quarts. I didn't know any different - I was answering the guy who asked about a GSR tranny.
Old Feb 2, 2004 | 06:59 AM
mmuller's Avatar
Mad Scientist
Default Re: (JimBlake)
yeah, the gm synchromesh doesn't work miracles, but if your synchro is not that fucked it will help the grinding; you say that it slightly grinds so it should help
Old Feb 2, 2004 | 07:09 AM
tgreaves's Avatar
Default Re: (mmuller)
It is just a slight grind when shifting at higher rpm's.. Ill get 3 quarts just to be sure..
bertsb18hatch
Apr 6, 2008 09:45 AM
b16a27
Mar 26, 2005 10:08 AM
e13ctron
May 4, 2004 10:26 PM
Brian-Brian
Jul 22, 2003 08:56 PM
sl0wED
Feb 14, 2003 06:10 AM
