Cold morning starts.............
Old Jan 29, 2004 | 08:46 AM
turboxsi's Avatar
Default Cold morning starts.............
When its cold outside and my car has sat over night, the next morning when i try to start the car i turn the key and NOTHING. No crank (fuel pump turns on) just a click from the engine bay as i let off the key . And other times i will try to start the car there is like a 5 sec delay of nothing, then BAM the engine just turns right over with one crank of the starter.
Already got a new battery. Could it be somthing with the ignition switch or bad starter? TIA
Old Jan 29, 2004 | 01:33 PM
JimBlake's Avatar
Default Re: Cold morning starts............. (turboxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboxsi &raquo;</TD></TR><TR><TD CLASS="quote">... Could it be somthing with the ignition switch or bad starter?</TD></TR></TABLE>Either one. Next time you try it, have someone rap on the starter with a broom handle or a screwdriver. If this kicks the starter into working, then you know it's the starter.
If not, I guess the ignition switch, but maybe the wiring in between.
b18cEK
21
Apr 9, 2014 07:14 PM
wesk18
Dec 6, 2010 11:06 PM
reelhybrid
Feb 1, 2007 03:05 PM
sohctodohc
Oct 18, 2006 09:08 PM
Mavrick
Mar 4, 2006 03:49 PM
