TPS problem... (Yes I searched)
Old Jan 29, 2004 | 01:59 PM
UNDER PRESSURE's Avatar
Default TPS problem... (Yes I searched)
The problem is that everytime I punch the gas once i get to about 5600 rpm my check engine light comes on and guess what it's a code 7 (TPS). Do you guys think it just needs to be calibrated or is it bad? another thing at partial throttle the car boggs but if I open it up a little it runs fine. When I calibrate the TPS do I turn the ignition on and do I check the voltage at the ecu or at the plug behind the throttle body?
UKintegra
Jun 8, 2011 12:32 PM
spooledhonda
Apr 5, 2006 06:02 PM
crnimacak
Jan 19, 2006 04:59 PM
Catman316
15
Apr 14, 2005 03:31 PM
UNDER PRESSURE
10
Jun 15, 2004 04:09 PM
