Heating problem with jdm b16
Old Jan 29, 2004 | 06:41 AM
SupaFly_Honda's Avatar
Default Heating problem with jdm b16
I have a 94 cx with a jdm b16 with the regular bolt on. I/H/E and skunk2 chipped p28. My fuel is set at 38 psi. The motor is having trouble heating up normally. On cold(30 degrees) mornings I usually warm up the car for about 10 minutes before I got to work, but the temperature gauge hardly goes up. I feel on the motor to see if its hot, but its not. I'll drive for about 5 to 6 miles and the car would still be right at the bottom line, or barely above it. The odd thing is that sometimes it'll even drop back lower. Then on warmer days(60 degrees) the car would warm up normally. Can anyone tell me whats wrong?
Old Jan 29, 2004 | 07:08 AM
mmuller's Avatar
Mad Scientist
Default Re: Heating problem with jdm b16 (SupaFly_Honda)
change the thermostat
Old Jan 29, 2004 | 10:55 AM
92civeg's Avatar
Default Re: Heating problem with jdm b16 (mmuller)
mine does the same thing (92 b16a) the temp gauge wont move until ive been driving it for about 20-25 min...ive never though anything of it because the cx motor that was in before did the same thing
Old Jan 29, 2004 | 10:59 AM
wickedEFguy's Avatar
what degree thermostat do you have in?
Old Jan 29, 2004 | 11:08 AM
92civeg's Avatar
Default Re: Heating problem with jdm b16 (wicked B16)
mines stock
Old Jan 29, 2004 | 11:21 AM
Default Re: Heating problem with jdm b16 (92civeg)
I would replace the thermostat with a higher degree or just replace it with a stock one and see how it reacts.
I think it's just the thermostat
Old Jan 29, 2004 | 02:07 PM
I recently changed out the thermostat about 2 months ago. It wasn't an oem from honda, but a cheapo from autozone.
Whats the highest temperature themostat available?
A.R
Aug 11, 2013 06:09 AM
bakomack
11
Jul 24, 2009 10:50 AM
