HELP! car wont start
Old Feb 1, 2004 | 05:23 PM
sirb18a's Avatar
Default HELP! car wont start
i have a 92 civic dx with a b18 swap... its been running good for awhile until today... the engine basically wont turn over... i already got my battery changed and checked... i got my starter tested and it is still in good shape... any suggestions are welcome... thanks
Old Feb 1, 2004 | 05:27 PM
ITR_1211's Avatar
Default Re: HELP! car wont start (sirb18a)
can you hear your starter? does it crank? double-check your ground wires also
Old Feb 1, 2004 | 05:29 PM
sirb18a's Avatar
Default Re: HELP! car wont start (Darryl Musashi)
it does not crank... ive checked the groundwires already... i can hear the fuel pump turning on but it does not crank...
Old Feb 1, 2004 | 07:22 PM
ITR_1211's Avatar
Are you getting any spark?
Old Feb 1, 2004 | 07:24 PM
hondatim's Avatar
if it's not cranking then I would be safe to say that at this point he's not getting any spark either.
Have you tried turning engine over by hand to ensure engine even turns over?
Old Feb 1, 2004 | 09:01 PM
sirb18a's Avatar
ill try to turn engine by hand tomorrow...
Old Feb 1, 2004 | 10:53 PM
slixxracing's Avatar
Default Re: (sirb18a)
check the fuses by the battery and the fuses under the steering wheel...maybe it just blew a few or two.
Old Feb 2, 2004 | 08:02 PM
hondatim's Avatar
Well, any news?
Just curious...
Old Feb 2, 2004 | 09:25 PM
-=DPUO=-MUGEN's Avatar
spark plugs?
Old Feb 2, 2004 | 09:28 PM
hondatim's Avatar
Default Re: (-=DPUO=-MUGEN)
spark plugs shouldn't keep engine from physically turning over though...
Old Feb 2, 2004 | 11:45 PM
ryanstev's Avatar
Does your start click once, then nothing?
If so, there's dust in your solenoid, hit it with a hammer, not hard enough to damage it, but enough to move the dust around a bit.
Is your car a manual? If so, can you push start it?
Is your car an auto? Are you sure it's in park or neutral?
I've had to help lots of people with their car that won't start and after a couple minutes realise the gear isn't in P or N, although it looks like it is, wiggle the gear stick a bit.
Old Feb 4, 2004 | 10:44 AM
Default Re: (ryanstev)
[QUOTE=ryanstev]
QUOTE]
From my expereinces pushing starting isnt gonna help, its only if the battery is low and has no juice. But give it a shoot cause @ this point you've got nothing else to lose.
whit3tatt3dn3rd
Jun 24, 2013 10:40 AM
j4s0n1337
41
Feb 19, 2011 07:50 PM
Type_R_Lover
Jan 19, 2010 06:19 PM
ekVtecPower
21
Apr 1, 2006 10:35 PM
easyFOsheezy
Jan 28, 2006 12:25 AM
