obd2a to obd2b adapter? help! ! ASAP
Old Jan 27, 2004 | 11:51 PM
tokes's Avatar
Default obd2a to obd2b adapter? help! ! ASAP
im running a 2000 B16 motor on my 96 civic EX and im using the harness from the 96 ex civic onth the B16. i have e 2000 B16 ecu but im running the 96 ex ecu due to the EX harness. is it better to just get a p28 chipped and the obd2a to obd1 adapter? and how much will it be?? or does anyone know how to make it?
Modified by tokes at 9:09 AM 1/28/2004
Old Jan 28, 2004 | 08:46 AM
lovitalracer's Avatar
Default Re: obd2a to obd2b adapter? help! ! ASAP (tokes)
You can run a 97 to 98 gsr ecu . But if you want to convert it which will give you more power or more of a ecu tunning fact than change it over to OBD1 . I have some in stock , give me a buzz .
Old Jan 28, 2004 | 09:21 AM
PHiZ's Avatar
Default Re: obd2a to obd2b adapter? help! ! ASAP (lovitalracer)
I would NOT reccomend a GSR ecu, the fuel and ignition curves are setup for IABs and vtec, so there will be two pronounced shifts in the maps.
If you can find an OBD2a B16 ecu (out of a 96-97 Del Sol Vtec). That would work, there may be a japanese counterpart available.
OBD2a-OBD1 harness and a chipped P28 is a good idea also, and may be easier to find thatn the Del Sol Vtec OBD2a ecu.
-PHiZ
Old Jan 28, 2004 | 09:32 AM
mmuller's Avatar
Mad Scientist
Default Re: obd2a to obd2b adapter? help! ! ASAP (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">
-PHiZ</TD></TR></TABLE>
Old Jan 29, 2004 | 10:03 PM
tokes's Avatar
anyone got the adapter and ecu for sale? ? let me know! !
MistahJer
Mar 17, 2006 04:21 PM
bmxmarine
Mar 7, 2005 08:48 AM
bmxmarine
May 10, 2004 01:12 PM
slowestcivicever
Feb 18, 2002 05:01 AM
