HID HELP
Old Jan 27, 2004 | 04:59 PM
ChadB's Avatar
Default HID HELP
I have a set of IS300 HID blubs and blaster.. I hook them up and they keep blowing fuses.. Could someone show me a digram and on how to hook these headlights up.. PLEASE HELP.. Pics!! Would HELP..
Old Jan 27, 2004 | 05:04 PM
ITR_1211's Avatar
Default Re: HID HELP (ChadB)
did you upgrade your stock fuses?
Old Jan 27, 2004 | 06:19 PM
VTECorona's Avatar
You will need 15-20A fuses to power the ballasts. This is a common problem to people that install kits. I believe the stock fuse is 10A, which is too low.
Old Jan 27, 2004 | 07:14 PM
ITR_1211's Avatar
Default Re: HID HELP (VTECorona)
Also make sure your harness is'nt backwards when plugged into the ballast
Old Jan 27, 2004 | 08:50 PM
EkDave's Avatar
I had the same problem. Changed my fuses to a higher rating (12 or 14) and that fixed the problem. Supposedly I hear you can blow some wires out if there's too much voltage running through them. Not sure if that's true. Anyhow, if it does, good luck locating the spot where it blew.
Old Jan 28, 2004 | 08:31 AM
ITR_1211's Avatar
Default Re: HID HELP (EkDave)
I've heard of harnesses melting, its always better to use thicker guage wiring for your harnesses
Old Jan 28, 2004 | 05:31 PM
ChadB's Avatar
Default Re: HID HELP (Darryl Musashi)
I've heard the same thing to.
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darryl Musashi &raquo;</TD></TR><TR><TD CLASS="quote">I've heard of harnesses melting, its always better to use thicker guage wiring for your harnesses</TD></TR></TABLE>
Old Jan 28, 2004 | 05:40 PM
VTECorona's Avatar
You can make your own harness with about 20$ worth of stuff from radioshack. Mine's been running strong since July. You will need 12 guage wire, 1 30A automotive relay, 3 inline fuse holders with 1 30A and 2 15A fuses, some zip ties, an assorted pack of connecters for connecting the wires to your battery and ground, and some butt connectors. I drew out a diagram in MSPaint and posted it on hidforum here. If you need any help pm me
Old Jan 29, 2004 | 07:17 PM
ChadB's Avatar
Thank you... That helps me out alot with your pics..
Old Jan 29, 2004 | 08:41 PM
ITR_1211's Avatar
Adding the relay will prevent melting the harness if you run it off the stock system?
Old Jan 29, 2004 | 10:04 PM
VTECorona's Avatar
Using the wiring harness allows the ballasts to be powered directly from the battery rather than through the factory harness, which was only meant to handle 12V 55 watt bulbs. You can probably get away with using the stock harness but using a harness with a relay ensures the ballasts are getting all of the power that they need and you aren't risking damage to the stock harness.
Old Jan 30, 2004 | 01:03 AM
T.J.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darryl Musashi &raquo;</TD></TR><TR><TD CLASS="quote">did you upgrade your stock fuses?</TD></TR></TABLE>
Yeah just upgrade your fuse your going to need at least a 20 amp fuse to run them
Old Feb 2, 2004 | 03:18 PM
ChadB's Avatar
They work!! Now I just need help with my fog lights..
Old Feb 2, 2004 | 04:08 PM
VTECorona's Avatar
Default Re: (ChadB)
What kind of help
Old Feb 4, 2004 | 04:47 PM
ChadB's Avatar
Default Re: (VTECorona)
I need to wire up my fogs to the oem switch.. anyone?
Old Feb 12, 2004 | 08:05 AM
VTECorona's Avatar
Default Re: (ChadB)
It can't be too hard.. Just like wiring up any switch to a lighting device. Did the fogs come with a relay or is it just a (+) or (-) circuit that runs through a switch?
vip001
Lighting
Oct 27, 2012 06:52 AM
immajackuup
Dec 19, 2008 07:19 AM
Devine
Nov 28, 2005 02:31 PM
CoolKat
Dec 3, 2003 08:54 PM
