ls/vtec in a 90 integra
Old Jan 31, 2004 | 08:33 PM
turbohondask's Avatar
Default ls/vtec in a 90 integra
I am having a problem with my ls/vtec in a 90 integra it has a type r pistions, and the normal stuff for ls/vtec, except the type r manifold, I did the vaccum as the stock stuff it works find but it will not hold idle. I am using 94+ IAC valve, and throttle body with cold start valve the ( the thing on the bottom). I cannot get this thing to idle at all when it is under 1k it bogs and dies.
The things I might think it is either
stock ls computer( using until pr3 comes in)
distrubour is broken ( ls one the legs are cut)
IAC valve not compatible
compression
anyone have suggestions or comments that can help
thanks
Old Feb 1, 2004 | 02:54 AM
Default Re: ls/vtec in a 90 integra (turbohondask)
bump
Old Feb 1, 2004 | 10:04 AM
some advice please
Old Feb 1, 2004 | 01:27 PM
Spartanic's Avatar
Check the basic things first before you start replacing stuff, such as all battery grounds and make sure they are tight, check idle rpm and compare to stock specs found in service manuals, adjust as needed, check cam timings and adjust to stock, check ignition timing and adjust to stock timing, check distrubitor igniter and make sure its in working condition (the igniter can cause a lot of start up problems).
Sometimes its the basic things that cause so much trouble.
Old Feb 1, 2004 | 04:11 PM
Default Re: ls/vtec in a 90 integra (Spartanic)
thank you for the info, the car is not holding idle it dies but if i keep on the gas pedal it will be on
Old Feb 1, 2004 | 04:53 PM
C8V6C's Avatar
Might not be your prob, but my ground to the coil, i think, was loose
Just tightened it, and the car has been good
Old Feb 2, 2004 | 07:50 AM
Default Re: ls/vtec in a 90 integra (C8V6C)
bump
Old Feb 3, 2004 | 06:17 AM
bump
aCuRaLeJeNd26
Jun 3, 2006 07:32 PM
crxsi8
Jan 13, 2006 03:52 PM
luda98
Oct 14, 2004 07:05 PM
sk8phaze
Aug 16, 2002 10:45 AM
