ignition question please help
Old Jan 30, 2004 | 06:17 PM
dohc-nyne's Avatar
Default ignition question please help
my freind has a 93 integra ls and one nite his car just wouldnt start so the next day we checked it out and found their was no spark from the dist. cap so we replaced the rotor and cap stil didnt work then we replaced the igniter inside the distributor and then we fired it up and it still wouldnt start,,,,it just keeps turnin over but will not start no spark....what else could it be? ignition coil?? or relay? any help is appreciated....
Old Jan 30, 2004 | 06:26 PM
Kendall's Avatar
The ignition coil is suspect, but you may need a whole new distributor.
Old Jan 30, 2004 | 06:44 PM
tegbuilder's Avatar
Default Re: (Kendall)
Have you checked all these?
Engine rotates but will not start
- Fuel tank empty.
- Battery discharged.
- Battery terminal connections loose or corroded.
- Leaking fuel injectors, faulty fuel pump, faulty fuel pressure regulator.
- Fuel not reaching the fuel rail.
Ignition components damp or damaged.
- Worn, faulty or incorrectly gapped spark plugs.
- Broken, loose or disconnected wiring in the starting circuit.
- Loose distributor is changing ignition timing.
- Broken, loose or disconnected wires at the ignition coil or faulty coil.
Old Jan 30, 2004 | 07:11 PM
boostn420's Avatar
Default Re: (tegbuilder)
Disconnect the 2 wires to the coil, connect a test light between them, crank the engnie over. If you have a blinking light there then the coil is bad. If not, you should check the continuity of the wires between the ecu and the distributor.
Old Feb 1, 2004 | 03:22 PM
dohc-nyne's Avatar
Default Re: (boostn420)
i tested the coil and it is reading just fine....its gotta be something even before the coil any ideas?
Old Feb 1, 2004 | 04:08 PM
Chiovnidca's Avatar
Default Re: (dohc-nyne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohc-nyne &raquo;</TD></TR><TR><TD CLASS="quote">i tested the coil and it is reading just fine....its gotta be something even before the coil any ideas?</TD></TR></TABLE>
Did you try the testlight check suggested by boostn420? Might help narrow down the problem.
Old Feb 1, 2004 | 06:31 PM
dohc-nyne's Avatar
Default Re: (Chiovnidca)
ill try the ecu conection to the distributor next
Old Feb 1, 2004 | 11:06 PM
slixxracing's Avatar
hmm..i had an experience w/ this once on my gsr. motor was running fine when i pulled it out to do a h22 swap, but then when i went to install the gsr into my hatch, motor wouldnt start no more. i couldnt understand why...i checked pretty much everything i could like how you did..but found out my timing was off. I have no clue how the timming was off, but it was off alot. I just redid my timming and wham...it cranked right up. Check your timming...if not timming..fuses maybe.
Old Feb 2, 2004 | 12:44 AM
dohc-nyne's Avatar
Default Re: (slixxracing)
thanks ill check on that
Josh Jennings
Oct 30, 2016 03:35 PM
ryguy1220
Aug 23, 2014 12:06 AM
Will Johnston
May 20, 2012 08:23 PM
boble94
Mar 29, 2010 06:18 PM
Mr. V
Classic Hondas
Jan 8, 2010 07:27 AM
