What will make your car stall at idle
Old Feb 1, 2004 | 03:15 PM
Br1anPham's Avatar
Default What will make your car stall at idle
What can make a car stall at idle? i tried searching and most idle problems are caused by a iacv, mine is fine.
Old Feb 1, 2004 | 10:13 PM
Br1anPham's Avatar
Default Re: What will make your car stall at idle (Br1anPham)
bump
Old Feb 2, 2004 | 10:04 AM
tgreaves's Avatar
Does it not idle at all.. Or is it just when your revving down to idle..
Old Feb 2, 2004 | 04:25 PM
Br1anPham's Avatar
Default Re: What will make your car stall at idle (tgreaves)
it idles for a while and eventually drops so low then it stalls.
Old Feb 2, 2004 | 05:06 PM
im_the_teacher's Avatar
what make your car die? if your car do not have enough air it will die.
wrong timing can cause your car to idle too low and eventually die.
there many other simple things that make your car die.. i work for a dealership so i cannot give out too much info..sorry
Old Feb 2, 2004 | 05:17 PM
zangiefisgod's Avatar
first check for a vaccuum leak, its an easy problem to find and fix
Old Feb 2, 2004 | 05:29 PM
turboxsi's Avatar
Default Re: What will make your car stall at idle (im_the_teacher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by im_the_teacher &raquo;</TD></TR><TR><TD CLASS="quote">
there many other simple things that make your car die.. i work for a dealership so i cannot give out too much info..sorry </TD></TR></TABLE>
WTF are you talking about, who cares!! What the hell do you think HT is for? Its one method of help to avoid your dealerships crazy high prices for simple fixes. So if you don't have anything that can help then don't say **** at all.
Back to the topic, check your idle screw for starters (simplest stuff first), also check for any vaccuum leaks as that was a problem i had with my idle not being stable. Then lastly i would check your timing if you say your iacv is fine. Other then that we would need more info on engine or maybe if there is a CEL (could be grounds or somthing electrical). Good luck!!
dc4b20
22
Dec 3, 2012 09:54 PM
bokals
Mar 8, 2007 02:26 PM
FloridaCivic
18
Feb 24, 2007 12:23 PM
hondachris1994
23
Mar 11, 2006 08:47 AM
