car is bucking around 2g
i cant seem to find the problem besides im throwing a CEL 14 - IAC , but my car will start bucking wildly when it gets neer 2000 rpms , could it be the IAC?? any thing elses causing this ??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetStars »</TD></TR><TR><TD CLASS="quote">i cant seem to find the problem besides im throwing a CEL 14 - IAC , but my car will start bucking wildly when it gets neer 2000 rpms , could it be the IAC?? any thing elses causing this ??</TD></TR></TABLE>
yep, the IACV has this effect when its not connected.
whats your full car & engine scenerio? just drop a motor in your car recently or wut ? need year & type of car info so we tech people can help you.
yea i just therw a motor to gether so i can have my car on the road but yea i just droped it in . my car wuse to be OBD2 but i had this motor and swaped out in jectors alt and distrbuter to make it compatible but yea i ther a CEL 14 its hooed up but i jaced the plug frun a OBD1 harnes and spliced it on the OBD2 harnnes ... i saw the OBD2 harness for the iac plug has 3 wires and the OBD1 has 2 wire pluge .. could it be possable i have the worng ones hooked up ....???
not a whole lot of help, because I dont know the name of the thing,
but after I did my swap I got a IAC code. I hooked the IAC plug up
to the black cylinder looking thing to the right of it on the IM. Messed
with the IAC, cleaning it and such a few times, couldnt figure it out,
the relized I had it hooked up wrong. Stupid mistake, easy to fix.
well i switch 2 plugs around but then i trew 2 codes , the IAC code and the intake manifold temp sensor so that dident work , i guess ill do sum tril and error stuff with the plug since the harness on my OBD2 civic has 3 wires and the plug has 2 that i sliced on .....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetStars »</TD></TR><TR><TD CLASS="quote">yea i just therw a motor to gether so i can have my car on the road but yea i just droped it in . my car wuse to be OBD2 but i had this motor and swaped out in jectors alt and distrbuter to make it compatible but yea i ther a CEL 14 its hooed up but i jaced the plug frun a OBD1 harnes and spliced it on the OBD2 harnnes ... i saw the OBD2 harness for the iac plug has 3 wires and the OBD1 has 2 wire pluge .. could it be possable i have the worng ones hooked up ....???</TD></TR></TABLE>
ok, it sounds like you didn't completely perform the IACV fix. So you're car is OBD2 eh ? what exact year is it ? this matters because the IACV fix slightly differs between 96-98 & 99-01 civics.
For the meantime, if your car is between 96-98 check out this wiring diagram of mine here for the complete IACV fix:
http://www.ff-squad.com/tech/w...8.jpg
http://www.ff-squad.com/tech/w...g.jpg
or if you own a 99-01 civic check this diagram out:
http://www.ff-squad.com/tech/w...1.jpg
bboylito
21
Mar 16, 2006 07:29 AM
