Would This Be Necessary? How To Install
Old Feb 1, 2004 | 07:27 PM
Full Race A6's Avatar
Default Would This Be Necessary? How To Install
Modified by Not Stock at 11:38 PM 2/14/2004
Old Feb 1, 2004 | 07:50 PM
hondatim's Avatar
Default Re: Would This Be Necessary? How To Install (PIMPIN)
That type of A/F guage will do really no good. Unless you have a wideband O2 with display, these others are pretty much for looks IMHO. You definitely do not want to tune or trust it for reading possible issues with engine.
Just my 2 cents though....
Old Feb 1, 2004 | 07:51 PM
Default Re: Would This Be Necessary? How To Install (hondatim)
Ya Im not looking to tune my car at all.
Just thought it would help so I didnt spray when my car was leaning out and I could watch it as I was spraying to make sure everything safe.
Old Feb 1, 2004 | 07:54 PM
hondatim's Avatar
Again, really won't tell you much, especially when spraying.
Sorry ...
Old Feb 1, 2004 | 08:15 PM
boostn420's Avatar
Those things suck, they arent reliable at all dont waste your money. With just a 65 shot you should be just fine I used to squeeze 75 on my sohc without any problems.
Old Feb 1, 2004 | 08:22 PM
Default Re: Would This Be Necessary? How To Install (boostn420)
On stock fuel pump and injectors?
Old Feb 2, 2004 | 06:29 AM
tegon-gsr's Avatar
It should help at wot only and thats when you want to know whats going on when spraying i have the zex wet kit and it is activated at WOT. so i think it will be beneficial to you when at wot but during normal idle or daily driving it will just be a light show.
Old Feb 2, 2004 | 06:53 AM
Default Re: Would This Be Necessary? How To Install (tegon-gsr)
Ya guess I dont want it then. Might invest in a walbro 180 fuel pump fuel pump
Old Feb 2, 2004 | 07:00 AM
EE_Chris's Avatar
LM3914 Datasheet
This is the chip they use in that meter. Build one yourself for cheap.
Old Feb 2, 2004 | 07:11 AM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIMPIN &raquo;</TD></TR><TR><TD CLASS="quote">
Portable light show. Readings off of the stock o2 sensor.... suck. Its possible it might show you something at WOT, but these things really are more like a light show than a gauge reading.
Old Feb 2, 2004 | 07:15 AM
mmuller's Avatar
Mad Scientist
Default Re: Would This Be Necessary? How To Install (splitime)
as sayd above you can make your own
http://www.scirocco.org/tech/misc/afgauge/af.html
good article:
http://www.alltrac.net/tuning/afgauge.html#diy
Old Feb 2, 2004 | 08:33 AM
EG-lowrider's Avatar
I wish I knew before I bought mine, dosent do much to me either.
Old Feb 2, 2004 | 09:31 AM
Sliced Beard's Avatar
Default Re: (Broke@$$tuner)
hmmmmm i wonder if i can make my own wide band tuner
i will have to look into this
06rallyredsi
Honda Civic (2006 - 2015)
Dec 24, 2006 07:12 PM
andylawcc
Oct 1, 2006 08:18 PM
Traction
24
Jun 16, 2004 12:13 PM
hondaeg8
Jun 10, 2004 01:43 AM
AJTEG
May 12, 2002 08:36 AM
