skunk 2 spring rate formula>>
Old Dec 17, 2004 | 09:33 AM
graphic's Avatar
Default skunk 2 spring rate formula>>
first off i have the coilover front set for my 98 prelude..
there i s number on the side 0700.2.50.010
i called skunk 2 and the tech guy siad that the spring were rated 55lb/kg..
i asked him usually i here terms like 350lb/in..
he was like no we rate ours this way..
does anybody know how to convert to lb/in..
i did a search and someone said that the .010 are equalivent to 500lb/in...
OUCH if this is true it is giong to but a painful ride even w/ the tokico blues..
any HELP on this matter??
Old Dec 21, 2004 | 03:27 PM
Tyson's Avatar
Default Re: skunk 2 spring rate formula>> (graphic)
you read the .010 as 10,000kg/m which is 559 lbs/inch
skunk2 seems to use overly high spring rates. especially with civics and integras, which apparently now is the SAME they give for the prelude. shows how little thought they put into designing their kits....
MinimalXistance
Suspension & Brakes
Feb 11, 2006 05:19 PM
blulude92
Dec 29, 2005 09:21 AM
MechEng
Jun 4, 2003 01:04 PM
sporkcrx
Oct 23, 2002 07:13 PM
