how hard is it to put a 94+ LS in a 90 integra?
does anyone know how to put a b18b in a 90 integra. i would think its just straight bold in. also i plan on turboing it but cant find any high performance motor mounts for that year integra. will i need special motor mounts if i have about 300 hp or can i just use the stock b18b ones?
The lonbblock is a straight bolt in(use all of the existing mounts and mount brackets). You can just use the stock mounts and buy prothane or Energy Susp. inserts.
Phil
Phil
the swap is a straight bolt in like the other guy said.
Do you want to stay obd0 or convert to obd-1?? It's also tough for the 2nd gen to keep it's a/c with turbo in it. Just a heads up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by auburnBoy »</TD></TR><TR><TD CLASS="quote">what are prothane and energy susp. inserts?</TD></TR></TABLE>
They are urethane(hard palstic basically) inserts that you place into the existing mount to reduce engine movement. I had the prothanes in an sohc hatch I had back in the day and I liked them.
The motor/tranny will just bolt right in. You'll have to get the OBD-1 (94-95 Integras) or the OBD-2 (96+ Integras) wiring harness conversion to run with your OBD-0 ECU, or whichever way you want to go. Other than that everything else is the same.
