Tranny problems
Old Dec 13, 2004 | 03:58 PM
sirex89's Avatar
Default Tranny problems
Ok... I dont know exactly what happened to my tranny today. I'll just tell you want I can do or what ever and any ideas will help... Ok! so to say... first just to let you know... I have blown the CV joint on the driver side. I have a 89 CRX Si w/ a JDM B16 swap and LSD. Ok I was driving and i shifted from 1st to 2nd. I heard a pop and then I had no reaction from acceleration or anything. SO, I pulled into a parking lot. Stop. pull emergency brake and look under the car. Nothing seemed wrong except that the driver side cv axel was broke. Well I can push the clutch in and put it into 1st and let off the clutch and the car will start to roll. But when I try to accelerate all my engine does is rev up. nothing else. Then I can push the clutch in and shift to 2nd. The car will speed up to about 20 at idle rpms for second. I can rev on it and it does nothing. I can shift through all 5 gears and go to about 45 mph. But When I get on the gas it does nothing. I have no idea if its something with the throw-out bearing or something internal with the gearing of the tranny or what. I know nothing about trannys except how to replace the clutch. So, any help??? Please...
Old Dec 13, 2004 | 08:06 PM
Dan GSR's Avatar
Default Re: Tranny problems (sirex89)
change your axle
Old Dec 14, 2004 | 05:15 AM
sirex89's Avatar
Default Re: Tranny problems (Dan GSR)
yea... i am getting the axel in about an hour or so... is that all you think it is... I have nad the same reply from another guy at clubsi.com.... I hope that is all it is... I cant afford to rebuild the tranny or anything right now...
Old Dec 14, 2004 | 07:22 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
If you have LSD you should still move a little, and it will probly feel like crap. Change the axle and see if its okay.
Old Dec 14, 2004 | 11:58 AM
sirex89's Avatar
Default Re: Tranny problems (JDM_Ej)
ok thanks... i just got the new axel and ill change it tonight when i get time... I just wasnt sure if that was all it was or what to do if i install the new axel and it still doesnt run... that will suck ***... so i dont know what ill do at that point... so i hope its just the axel is causeing the LSD to not work corectly... so if not its for sale.. thats all i can say
supereg2
Mar 21, 2008 09:51 AM
WreckedTeggie
Nov 5, 2004 11:01 AM
wreckedmyteg
Jun 9, 2004 07:22 PM
projectM
Jan 10, 2003 05:36 AM
chirp2hrd
10
Jan 1, 2003 09:47 AM
