Hondata Gsr Base Map
Old Dec 18, 2004 | 10:21 AM
TurboTeG4's Avatar
Default Hondata Gsr Base Map
I burned a p72 map on a p28 ecu and ran it in my 94 gsr, but when at idle and I tap on the gas I can feel it hesitate for just a second. How come the base map is doing this?
>>Hondata
Chances are there is a difference in setups between the car we used to generate the base map and you car. You can try altering the throttle tip in fuel adjustment to see if that fixes the flat spot, but really it would be a good idea to dyno tune the vehicle.
My throttle tip is at 1, which direction should it be altered too, hesitation when tap the gas from a idle.
Old Dec 18, 2004 | 10:43 AM
Dragline's Avatar
Default Re: Hondata Gsr Base Map (TurboTeG4)
I'm not to experience with hondata but it sounds like a TPS problem,or can you and more timing at this point in the map it should take care of it.
GABOCRX
Engine Management and Tuning
Jan 13, 2011 04:49 AM
NAEH2NA
11
May 1, 2005 11:46 PM
sneakypete
Feb 18, 2004 10:24 AM
01ITR#700
Jun 19, 2003 02:20 PM
