oil in radiader??
Old Dec 16, 2004 | 01:51 PM
dumpeDc2's Avatar
I'm a Jackass
Default oil in radiader??
ya I blew my head gasket and there is like sluge oil in my raderader. Like when I stick my finger in where the upper hose goses you can feel it all gunked up. how can I remove this or can I run my car like it without a problem? oh and it has bin sitting outta the car for a good month.
Old Dec 16, 2004 | 05:47 PM
PrettyLude's Avatar
flush your cooling system as much as you can
Old Dec 16, 2004 | 06:02 PM
chriskona's Avatar
Default Re: oil in radiader?? (dumpeDc2)
this has happen to me,
I kept flushing HOT water into the system for hours LOL.
than i removed the radiator and hoses. flushed the hot water over and over into the radiator until clear water came out. same for the hoses.
im sure theres a better way, but this is the home way i did LOL.
Old Dec 17, 2004 | 04:11 PM
dumpeDc2's Avatar
I'm a Jackass
Default Re: oil in radiader?? (chriskona)
K I will try running hot water through it.
Old Dec 17, 2004 | 04:32 PM
Dragline's Avatar
Take it to a radiator repair shop they will be able to flush it for like $25, hot water will not break down oil to remove it.
Old Dec 17, 2004 | 07:19 PM
dumpeDc2's Avatar
I'm a Jackass
Default Re: oil in radiader?? (dragline)
ya dragline your right, I tryed running boiling water through it with crapy rezults.
Old Dec 18, 2004 | 05:26 AM
atcrx's Avatar
try flushing it with a radiator flush which is basically soap. Do not use dish soap or laundry soap. You can use dishwasher soap it doesn't suds up like regular soap. I had a customer buy car wash soap one time and used it as radiator flush . It really made a mess. Kinda looked like a suds explosion.
Old Dec 18, 2004 | 08:02 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: oil in radiader?? (atcrx)
I used the prestone cooling system flush.
Old Dec 18, 2004 | 11:04 AM
dumpeDc2's Avatar
I'm a Jackass
Default Re: oil in radiader?? (LSVTEC 91 Civic)
coo thanks for the help Ill try flushing it my self because 25bucks is kinda alot.
Old Dec 18, 2004 | 11:33 AM
FairlightRacing's Avatar
DO NOT RUN YOUR CAR LIKE THAT!!!!!!!!!!
My buddies engine blew a hole in the side of the block because his headgasket was blown and he kept driving it. Replace the head gasket. Drain the oil, replace the oil filter and then readd new oil. Then hold a hose to the radiator and the radiator hoses to the block for a good five minutes. That will help flush everything out. That should do it. Have phun!
Old Dec 18, 2004 | 02:30 PM
dumpeDc2's Avatar
I'm a Jackass
Default Re: oil in radiader?? (FairlightRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumpeDc2 &raquo;</TD></TR><TR><TD CLASS="quote">ya I blew my head gasket and there is like sluge oil in my raderader. Like when I stick my finger in where the upper hose goses you can feel it all gunked up. how can I remove this or can I run my car like it without a problem? oh and it has bin sitting outta the car for a good month.</TD></TR></TABLE>
I was running with the head gasket blown for a good 3 months, went 13.4 with it. I just got done with a rebuild all new gaskets, pumps, b16 head , blah blah.
I just got back form autozone and they dident have any kinda radiader flushing fluid that you can just use without running the car. I dont want to flush it like that because the block and head is super clean sence it just came out of the machine shop. I will probley just take it to a radiader repair shop and have it done.
90dxcrx
Apr 5, 2012 02:30 PM
javifunksEK
Apr 16, 2010 08:00 AM
Kafelatte
Jan 10, 2007 10:30 AM
noob101
Apr 27, 2006 05:09 AM
MugenB16A2
Mar 2, 2004 07:48 PM
