what sensor is this?
Old Dec 13, 2004 | 01:05 PM
jbell's Avatar
Default what sensor is this?
tia.
Old Dec 13, 2004 | 01:34 PM
drdisco69's Avatar
Default Re: what sensor is this? (jbell)
That'd be your oil pressure sensor. It's only good for the idiot light in the dash.
Man, New Jersey sucks. Corrosion much?
Old Dec 13, 2004 | 01:59 PM
civic-4-ges's Avatar
Default Re: what sensor is this? (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">That'd be your oil pressure sensor. </TD></TR></TABLE>
IM in maine and my brackets don't look that corroded!!!
Old Dec 13, 2004 | 02:08 PM
hondaracing1on12004's Avatar
Default Re: what sensor is this? (civic-4-ges)
you can also swap the old sesor out and put an oil pressure gauge in. That would be cool.
Old Dec 13, 2004 | 02:27 PM
jbell's Avatar
Default Re: what sensor is this? (hondaracing1on12004)
motor is corroded because it was stiing outside.
see here: https://honda-tech.com/zerothread?id=1084207
Old Dec 13, 2004 | 02:31 PM
For the clean valvetrain
For the swap
Sorry Im not much on swapping
Old Dec 13, 2004 | 09:58 PM
jbell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote"> For the clean valvetrain
For the swap
Sorry Im not much on swapping</TD></TR></TABLE>
hrm... 103hp d15 or a 160hp b16.
$1000 for the motor...
i could put 1000 into that d and it wouldnt be as fast as the b.
enough said.
Old Dec 13, 2004 | 10:02 PM
jbell's Avatar
so is there a way to eliminate that sensor, since its cut, and put in another gauge?
Old Dec 14, 2004 | 02:02 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbell &raquo;</TD></TR><TR><TD CLASS="quote">hrm... 103hp d15 or a 160hp b16.
enough said. </TD></TR></TABLE>
Not enough said, only to you
Are you sure you can't put 1000 into a d and be as fast as a b?
Old Dec 14, 2004 | 09:14 AM
jbell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote">Not enough said, only to you
Are you sure you can't put 1000 into a d and be as fast as a b?</TD></TR></TABLE>
yes. well, unless i do one of those piece of **** turbo kits and run my motor at 14 pounds for 5 minutes until it blows.
jbell's Avatar
Old Dec 14, 2004 | 09:19 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbell &raquo;</TD></TR><TR><TD CLASS="quote">so is there a way to eliminate that sensor, since its cut, and put in another gauge?</TD></TR></TABLE>
you can just take it out and leave the harness unplugged.
remember that the threads on the block are bspt and not npt
Old Dec 14, 2004 | 09:21 AM
jbell's Avatar
Default Re: what sensor is this? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">you can just take it out and leave the harness unplugged.
remember that the threads on the block are bspt and not npt</TD></TR></TABLE>
what do bspt and npt mean?
wont it cause an idiot light to go on?
Old Dec 14, 2004 | 09:25 AM
mmuller's Avatar
Mad Scientist
npt= national pipe thread
bspt= British Standard Taper Pipe Thread
wont it cause an idiot light to go on? </TD></TR></TABLE>
no
Old Dec 14, 2004 | 12:40 PM
jbell's Avatar
ok, so what can i put in place of the stock sensor?
Old Dec 14, 2004 | 12:57 PM
you can put an oil pressure gauge in. just pull the black cover off and take the sensor out. The oil pressure gauge should come with several different fittings, one should fit.
Old Dec 14, 2004 | 01:01 PM
jbell's Avatar
any reccomendations what kind to go with?
Old Dec 14, 2004 | 05:31 PM
autometer seems to be the most popular. They do look nice.but they are expensive.I got sunpros for my civic. They where alot cheaper and they work pretty good. Theres some other brands out there you just gotta find them. Try http://www.nopi.com
Old Dec 14, 2004 | 06:38 PM
mmuller's Avatar
Mad Scientist
the gauge will not come with a bspt to npt adapter...
you have to buy it separately from lets say;
here:
http://www.mcmaster.com/
note that a NPT thread will fit a bspt, but not well and might leak
Old Dec 15, 2004 | 08:00 PM
I didnt have to buy any thing seperate from my sunpro gauge. It came with the one that i needed.
Old Dec 15, 2004 | 08:10 PM
jbell's Avatar
any link where to get the sunpro?
Old Dec 15, 2004 | 08:30 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaracing1on12004 &raquo;</TD></TR><TR><TD CLASS="quote">I didnt have to buy any thing seperate from my sunpro gauge. It came with the one that i needed.</TD></TR></TABLE>
no it didnt, it came with a npt adapter, not bspt( i have a sunpro mech. gauge too)
Old Dec 16, 2004 | 03:44 AM
VisualAutoMotoring's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbell &raquo;</TD></TR><TR><TD CLASS="quote">any link where to get the sunpro?</TD></TR></TABLE>
Ive seen Sunpro gauges being sold at local Advanced Auto Parts, Auto Zone, Pep Boys
shadhman
Jan 29, 2009 05:55 PM
Rukusmasta2
May 5, 2008 03:30 PM
RACEPAK
17
May 19, 2005 04:53 AM
LiLOtaku
Aug 20, 2003 06:16 AM
