Installing new water pump....
Old Dec 19, 2004 | 09:59 AM
si_hatch's Avatar
Default Installing new water pump....
I'am going to be installing a new water pump on my d16. I am not goin to replace the timing belt because it is fairly new so do I have to take the crank pulley off and remove the timing belt, or can i just take it off of the cam gear and and get the water pump out that way. Thanks
Old Dec 19, 2004 | 10:06 AM
DavidT or VajT's Avatar
Default Re: Installing new water pump.... (si_hatch)
You can just take the belt off the cam gear, if you can put it back on that way. Sometimes it's tricky but it's easier that way .
Rod.'s Avatar
Old Dec 19, 2004 | 10:57 AM
si_hatch's Avatar
Default Re: Installing new water pump.... (redturbocivic)
do I have to take the crank pulley off? I wanna make this as easy as possible
Old Dec 19, 2004 | 01:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si_hatch &raquo;</TD></TR><TR><TD CLASS="quote">do I have to take the crank pulley off? I wanna make this as easy as possible</TD></TR></TABLE>
You don't have to take the crank pulley off...It's pretty easy putting the belt back on w/out taking the crank pulley off. Do it!
Old Dec 19, 2004 | 05:53 PM
PrettyLude's Avatar
take it the crank pulley
Old Dec 20, 2004 | 11:49 AM
tgreaves's Avatar
Default Re: (PrettyLude)
You dont need to remove the crank pulley but your going to need to remove the lower timing belt cover to get to the water pump, and you have to remove the pulley to get the lower cover off.. If you dont have the lower cover on there for some reason then you can do it..
Old Dec 20, 2004 | 04:00 PM
grndcont's Avatar
when you remove the w/p some coolent is going to poor out right on the belt (bad). i would sugest removeing the pully. it's not that hard, put the car in 5th gear, aply the breaks and use a breaker bar.
Slacker93eg
Apr 1, 2016 12:28 AM
PreludePhill
Sep 10, 2007 04:59 AM
blackdelslo
Dec 15, 2004 02:02 PM
90AccordEX4Dr
Dec 10, 2003 09:04 PM
NateTEG95
May 30, 2003 09:24 PM
