GSR and LS crank difference
Old Feb 11, 2003 | 02:07 PM
decypha's Avatar
Default GSR and LS crank difference
Is there any difference? I have a bare GSR block and a LS B18B1 crank..i was wondering if there is any difference? if i did use it would i need GSR rods and LS pistons or the other way around? Thanks in advance.
Old Feb 11, 2003 | 07:52 PM
StorminMatt's Avatar
Default Re: GSR and LS crank difference (decypha)
LS cranks have a longer stroke (89mm vs 87.2mm).
Old Feb 11, 2003 | 09:52 PM
2000blackgsr's Avatar
Default Re: GSR and LS crank difference (StorminMatt)
if you use the ls crank, you have to use ls rods too.
Old Feb 11, 2003 | 10:18 PM
OEMJDM's Avatar
Default Re: GSR and LS crank difference (96coupe)
yup, what he said
Old Feb 11, 2003 | 11:01 PM
V3locity's Avatar
Default Re: GSR and LS crank difference (That is Wack!)
How do you use LS crank in a gsr block??? wouldn't it be too long and stick out of the gsr block??
Old Feb 11, 2003 | 11:37 PM
.(Lazarus).'s Avatar
Default Re: GSR and LS crank difference (illdezignzls)
No, it drops right in. Just remember to spin balance that bish first. The LS crank wasn't machined to spin above 7K from the factory. A balanced one is good to ~9.5K if its done pretty well.
Old Feb 14, 2003 | 09:13 PM
EG6owner-T's Avatar
Default Re: GSR and LS crank difference (ATXhybrid)
what can you do to an ls?
HondaAddict91
Engine Machining & Assembly
Oct 9, 2016 06:37 PM
jamescb77
Mar 1, 2007 07:45 AM
Mostecstreethb
Feb 19, 2007 02:19 AM
boostin4door
Feb 12, 2006 05:43 PM
86si
Nov 6, 2004 06:43 AM
