maximum injector size using stock ECU
Old Feb 9, 2003 | 08:05 AM
scsi's Avatar
Default maximum injector size using stock ECU
Hi guys,
Need some help...I currently using a JRSC 14 psi setup with a built 9:1 compresion engine. I already max out my current 310 RC injectors, what whould be the maximum injector size that I can use without replacing the stock ECU. Thanks.
Old Feb 9, 2003 | 08:17 AM
Just536's Avatar
Default Re: maximum injector size using stock ECU (scsi)
Are you sure you maxed out your injectors and not the stock ECU? The fuel maps in the stock ECU might not be allowing the injectors to give the max (pulse duration). You can go larger on the injectors and the ECU should contorl the A/F mixture.
Old Feb 9, 2003 | 08:54 AM
tominos's Avatar
get the vafc with injector box and use dsm 450ccs.
Old Feb 9, 2003 | 09:29 AM
sgT's Avatar
sgT
Default Re: maximum injector size using stock ECU (Just536)
Stock ECU runs 100% duty at higher rpm so its not the ecu.
310cc iks about as big as you can go on a stock ecu, but you should really
think about getting a real form of engine management.
Old Feb 9, 2003 | 11:26 AM
Ekasey's Avatar
Default Re: maximum injector size using stock ECU (sgT)
yeah i got 310's and with just an ecu and v-afc it struggs
Old Feb 9, 2003 | 11:32 AM
joe_bocc's Avatar
Default Re: maximum injector size using stock ECU (eLusive ek4)
310's
Violentpanda
Sep 11, 2018 02:57 PM
frostwhite_92
Engine Management and Tuning
Nov 12, 2011 12:33 AM
Zatar69
Nov 24, 2002 02:49 PM
