b20 + GSR tranny = ? how does this work...??
i got a GSR hydro tranny for my second del sol... i was wondering if i can just get a B20Z and run it NON-vtec for a wile..... what computer.. and what stuff would i needs......
GSR tranny will work great with a B20z motor. Yes you can run it non-vtec for a long time. Use a LS computer Pr4 OBD1 ECU. You can use a integra shift linkage, integra axles and your current delsol harness.
should be an excellent setup that will keep you at peak torque at all times.
ECU wise for OBDI you can go with PR4 or P74 or P75. (basically 92-5 integra). 92-5 DX P06 will work but tends to run lean.
axles from GSR/ITR/Si coupe (99-00)
siftlinkage from Del Sol
