stainless steel question. cutting welding.
Old Feb 10, 2003 | 03:28 PM
escocrx's Avatar
Default stainless steel question. cutting welding.
I have DC 4-2-1 stainless steel header. i happen to have a pr3 ecu which needs the 2 o2 sensors. Is stainless steel cuttable? other than plasma torch? i have a welder to do the welding, i just need the bungs for them. What kind of place would carry these bungs for the o2 sensors?
Old Feb 10, 2003 | 03:51 PM
texan's Avatar
Default Re: stainless steel question. cutting welding. (escocrx)
A carbide tipped drillbit or other cutter will have no problems with normal stainless steel grades.
Old Feb 10, 2003 | 04:11 PM
turbohonda's Avatar
Default Re: stainless steel question. cutting welding. (texan)
I get my O2 bungs from the auto parts store. They are made by K&N (the filter company).
Old Feb 10, 2003 | 05:05 PM
integra6650's Avatar
Default Re: stainless steel question. cutting welding. (turbohonda)
if im not mistaken welding stainless requires a ceartain feed wire you may also want to look for a stainless o2 bung mixing metals is not so easy i saw that fjo has 02 bungs but you can prolly find them at from an auto store like he said
Old Feb 10, 2003 | 06:57 PM
Neukin's Avatar
Default Re: stainless steel question. cutting welding. (integra6650)
i just ran one o2 senser and then split the wire before the ecu and ran the two wires to the ecu and it works fine. so really you dont need to do all that crap
Old Feb 10, 2003 | 07:54 PM
ChiBoy's Avatar
Stainless isn't easy to weld. If you do it wrong, the metal in and around the weld will rust away faster than regular steel.
Rywire
Jan 4, 2003 09:53 PM
T_Rex
40
Oct 29, 2002 12:27 PM
T_Rex
14
Sep 21, 2002 07:28 PM
Griffins_Importuning
Aug 4, 2002 01:15 AM
