Dyno #'s- Tuner guy's NEED HELP!
Old Feb 9, 2003 | 10:19 AM
WykidEH's Avatar
Default Dyno #'s- Tuner guy's NEED HELP!
I dyno'ed my the other day and "WTF", what going on. . . why is there a dip like that in my powerband? the swap has 40,000 miles on it. . . .
Set-up:
B16 bottom-end (rebiult)
GSR head (rebiult)
GSR cams
Skunk2 manifold
DPR H22 over-bore throttle-body 65mm
AEM ITR cold air
P30 ECU
GSR tranny w/ITR LSD
The runs 14'5's at like 98mph. Do I just need Hondata to tune it or what?
Jeramy
Old Feb 9, 2003 | 10:56 AM
joe_bocc's Avatar
Default Re: Dyno #'s- Tuner guy's NEED HELP! (WykidEH)
It looks like something happens at 4300 rpm. Is that your VTEC crossover? If it is it might be too low and cause your engine to bog. It's weird that your hp curve climbs pretty straight, but your torque curve is all over the place.
Old Feb 9, 2003 | 11:19 AM
Ekasey's Avatar
well first off it doesnt look like ythe setup the dyno to read torque right or maybe your torque curvie is just wierd but anyways. Yes you need to get hondata or V-afc to tune that ish and you will pull lots mroe power and get rid of that dip
Old Feb 9, 2003 | 11:40 AM
WykidEH's Avatar
Default Re: Dyno #'s- Tuner guy's NEED HELP! (eLusive ek4)
My crossover point is at 5500rpm's. . . .
Jeramy
Old Feb 9, 2003 | 11:58 AM
TEAMGENDAI's Avatar
I would definetly consider purchasing a hondata. I hope you have someone out there that can tune it. anyway good luck
Old Feb 9, 2003 | 10:41 PM
H25's Avatar
H25
get rid of that ecu. get a p28 and get it chipped. if you dont know anyone. i can do it for you. your making waay less power then you should be making.
Old Feb 9, 2003 | 10:50 PM
SIReg9's Avatar
Default Re: Dyno #'s- Tuner guy's NEED HELP! (LuckyRacing)
I'd start off buy purchasing a header...
Old Feb 9, 2003 | 11:24 PM
Rydaddy's Avatar
Not according to that dyno plot! Looks like it is activating at 4500...might want to check it again .
Old Feb 9, 2003 | 11:47 PM
texan's Avatar
It'd be a lot more productive discussion if you had a/f readings plotted along the RPM axis.
There's no point IMO to getting a chipped Honda ECU when the engine is so far away from anything Honda builds, just get a standalone to tune it properly. My guess is that the ECU has the entirely wrong fuel curve.
Old Feb 10, 2003 | 04:05 AM
MARC P's Avatar
Default Re: Dyno #'s- Tuner guy's NEED HELP! (SIReg9)
I second that, purchase a good header and a chipped P28 from Kenji, with a afc,fpr and go back to the dyno.
I also forgot to ask if you have cam gears, this will help also.
[Modified by MARC P, 8:06 AM 2/10/2003]
Old Feb 10, 2003 | 05:35 AM
Desslok's Avatar
Default Re: Dyno #'s- Tuner guy's NEED HELP! (texan)
I'm sure you need more fuel than stock. Do you at least have an adjustable FPR? Without the a/f curve it's harder to tell what it is.
Old Feb 10, 2003 | 05:53 AM
Misfit's Avatar
Default Re: Dyno #'s- Tuner guy's NEED HELP! (Desslok)
I believe the spike at 4300 is his aem spike. I have seen this before. and most people wereusing aem cai. shrugs...
Old Feb 10, 2003 | 06:03 AM
eg6ajk's Avatar
there are stock like programs which will extract few more horses from the motor while maintaing driveablilty. I personally dynoed tested few and they came up above the stock P30/P72 counter parts.
as far as his dyno plot, it looks like a P72 ecu running in a B16A.
Old Feb 10, 2003 | 06:05 AM
mattcxb18's Avatar
Sounds right to me.
Old Feb 10, 2003 | 06:27 AM
areyouasian's Avatar
i think you should pick up a fuel pressure regulator first, then buy a header and redyno the car. wouldn't hurt to have a hondata but a vafc is fine. for the price of the vafc though, i'd rather buy the hondata.
Old Feb 10, 2003 | 06:30 AM
CHEETAH's Avatar
your engine is not timed right ...
greg
hasty91ef
Aug 17, 2012 07:39 AM
dc4drewH
25
Aug 25, 2004 02:54 PM
zeptozorro
Jan 24, 2004 04:06 PM
WykidEH
Feb 9, 2003 07:33 PM
obd2gsr
Jan 3, 2003 03:42 PM
