bobbing idle??
Old Feb 10, 2003 | 06:03 PM
MeanGreenEG9's Avatar
Default bobbing idle??
When I'm at idle my rpm needle keeps bobbing up and down.. very subtle.. you couldnt even tell unless you looked close but I'm sure this shouldnt be happening.. any ideas on why this might be happening? clogged injectors? maybe need to clean the throttle body? TIA.
Old Feb 10, 2003 | 06:06 PM
texan's Avatar
Default Re: bobbing idle?? (B16aEJ)
It's normal, the ECU is constantly attempting to lean the motor out as far as possible and this causes a slight RPM fluctuation.
EDIT: Oh BTW, this phenomenon is much more noticable once you add a free flowing intake. The ECU's idle control maps are programmed for the greater air velocity the stock setup provides.
[Modified by texan, 7:18 PM 2/10/2003]
hondachris1994
10
Feb 25, 2006 02:37 PM
Daemione
Apr 24, 2004 03:20 PM
squirrel
Jan 15, 2003 11:38 AM
Black R
May 14, 2002 11:59 AM
vpforeva
Mar 30, 2002 10:40 AM
