apexi s-afc removal
Old Feb 9, 2003 | 09:36 AM
ExodusX187's Avatar
Default apexi s-afc removal
i'm selling my s-afc1 and i noticed it's plugged into some type of harness. the harness has wires coming out that are tapped all over the ecu. could i just unplug the s-afc from that harness and sell it, or do i need to remove the the whole harness? i plan on getting the s-afc2. wouldnt i just need to plug the s-afc2 into the existing harness?
Old Feb 9, 2003 | 09:39 AM
bluedelsol's Avatar
Default Re: apexi s-afc removal (ExodusX187)
undo the wires where they plug into the ecu wiring, but DONT cut the ecu wiring, you will not be able to sell it for nearly as mutch if you dont sell the harness with it.
Old Feb 9, 2003 | 09:41 AM
ExodusX187's Avatar
Default Re: apexi s-afc removal (bluedelsol)
couldnt i just buy a harness somewhere else and keep mine? i was looking earlier and it looks like it'll be a real pain in the *** to undo everything, there's electrical tape everywhere.
Old Feb 9, 2003 | 10:01 AM
bluedelsol's Avatar
you can but the harness, i wish you could because i have an sfc that needs one so i have to make one.
Old Feb 9, 2003 | 11:24 AM
tominos's Avatar
what?
Old Feb 9, 2003 | 01:26 PM
omahaturbocivic's Avatar
Acutally if you just unplug it your car will run like crap and throw a cel because the map sensor wire is cut when the safc is installed. The map sensor wire will be hooked up to the white and yellow wires off of the safc, unhook the white and yellow wires off each end of the map sensor wire then just splice the map sensor wire back together. The rest of the wire you can just unhook as long as the factory wire has not been cut.
Old Feb 9, 2003 | 06:37 PM
bluedelsol's Avatar
Default Re: apexi s-afc removal (tominos)
what?
i meant to say that you CANT BUY the harness, sorry for the typo
[Modified by bluedelsol, 3:37 AM 2/10/2003]
Old Feb 9, 2003 | 07:18 PM
ExodusX187's Avatar
Default Re: apexi s-afc removal (omahaturbocivic)
lets say i keep the harness. could i just plug in the s-afc2 or do i need to re-wire some stuff?
Old Feb 9, 2003 | 07:36 PM
bluedelsol's Avatar
I think they have differant harnesses since they have differant features. ( i'm pritty shure that's right but not positive)
luvmihatch
Jul 12, 2012 01:14 PM
Rheg6
Engine Management and Tuning
Mar 11, 2010 11:20 AM
sicivic
Jun 28, 2007 04:31 PM
inda14s
Jan 24, 2004 09:16 PM
yellaboi
Mar 2, 2003 12:07 PM
