what oil to use
Old Feb 9, 2003 | 10:32 PM
polycrx's Avatar
Default what oil to use
I have a crx with a b16. I drive it daily and hard. I going to change out my tranny oil what do I put in. Ive heard that redline oils are good and also just honda oe manual tranny fluid. Got any tips? The tranny is a y1 with a lsd.
Old Feb 9, 2003 | 10:34 PM
Kamin's Avatar
Default Re: what oil to use (polycrx)
honda MTF is the best.
Old Feb 9, 2003 | 10:59 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: what oil to use (Kamin)
I use the royal purple 75w90. it has a limited slip additive in it. it worked very well for me in my street car with type r lsd.
Old Feb 10, 2003 | 10:19 AM
ejprimo's Avatar
Default Re: what oil to use (MotorMatrix.com)
i believe the royal purple 75w90 is a GL-5 spec. tranny fluid. honda transmissions call for a GL-4 spec. tranny fluid.
after doing a little more research i found that royal purple is safe for GL-4 spec. transmissions.
[Modified by ejprimo, 11:27 AM 2/10/2003]
Old Feb 10, 2003 | 12:24 PM
polycrx's Avatar
how many bottles would i need
Old Feb 10, 2003 | 01:11 PM
ejprimo's Avatar
2.5 quarts.
Old Feb 10, 2003 | 09:27 PM
redhnda's Avatar
New User
10-30w mobil 1 and change your oil every 2000 miles. If you are running it's hard all the time.
[Modified by redhonda, 6:30 AM 2/11/2003]
Old Feb 10, 2003 | 11:12 PM
polycrx's Avatar
Default Re: what oil to use (redhonda)
I meant tranny oil but thanx anyways
Old Feb 11, 2003 | 05:49 AM
Arsenal's Avatar
"Change your oil every 2000 miles"
Waisting a lot of money there.
Old Feb 11, 2003 | 09:44 AM
Solo.Rex's Avatar
Default Re: what oil to use (Arsenal)
not really when you think about it. the more times you do it the less oil that breaks down in hte car the more protection in there .
so if the car always has clean oil then that is on less problem with the car.
i know this was for tranny oil but i thought i would throw my two sense in
my old car i used 0w30 . if you want expensive try that every 2000 miles
spinney
Sep 24, 2005 06:14 AM
patdemps
Jul 26, 2003 04:38 AM
fst96se
Mar 13, 2003 06:00 PM
lobaler+
Jul 18, 2002 10:15 AM
AutoXsi2000
Mar 8, 2002 10:37 PM
