School Tech Project
Old Feb 10, 2003 | 10:30 AM
AccordVtec's Avatar
Default School Tech Project
I have to come up with an invention. I really want to do something for performance but I also have to be able to make it.
Could anyone give me some ideas?
Thanks.
Old Feb 10, 2003 | 11:36 AM
steve_s's Avatar
Default Re: School Tech Project (AccordVtec)
Invent some intake which increases airflow to the engine. Something similar to whats out today but shaped diferently or something.
Old Feb 10, 2003 | 12:15 PM
AccordVtec's Avatar
Default Re: School Tech Project (steve_s)
What do you think would be better a ram air intake or cold air intake?
The intake idea would be pretty good because I could make it from carbon fiber.
And at my school they have a wind tunnel. I could test it out there.
Thanks for the suggestion.
Do you have any other ideas?
Old Feb 10, 2003 | 03:57 PM
HEAD's Avatar
you could make a fixture for flowing honda heads on a flow bench nobody has one on the market yet
Old Feb 10, 2003 | 04:12 PM
martini's Avatar
invent a variable length intake tube. long tube for the low rpms, when a longer pipe and more velocity is needed, shorter for higher rpms..
Old Feb 10, 2003 | 04:39 PM
texan's Avatar
If you have access to a wind tunnel and proficiency with molding cf, you could make a hood with an air intake NACA duct and measure the differences in engine power vs. aero Cd once installed. Or perhaps a carbon fiber undertray, and measure it's effectiveness from Cd drop (and lift coefficient if you can measure that).
Old Feb 10, 2003 | 04:50 PM
slomofo's Avatar
GDD Member
You should invent a quick release transmission, so that thousands of people could change clutches quicker.
Old Feb 10, 2003 | 04:59 PM
integra6650's Avatar
invent a replacement gauge pod for the integra dash stereo part sheet metal or plastic whichever very easy to make but noone sells them cut in 3 2 1/16th gauges and a avcr or vafc alittle help if you chose this the space is 7.5 by 4.5
the avcr is2x5 and the gauges the holes are 2 1/16th very easy to do and if it ever came out nice ill beyour first customer
Old Feb 10, 2003 | 05:43 PM
The HamsterBall's Avatar
you guys are the coolest
Old Feb 10, 2003 | 06:11 PM
Default Re: School Tech Project (HamsterBall)
correction 7x4.5
99accordsedanforsale
Classic Hondas
Nov 5, 2007 11:19 AM
Neptronix
Jun 25, 2007 09:39 PM
drh1
Oct 10, 2006 08:38 PM
xxaiphaxx
Nov 14, 2005 12:17 AM
infra
May 3, 2004 06:20 AM
