does anyone know flywheel surface height on an integra?
Old Feb 8, 2003 | 01:50 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default does anyone know flywheel surface height on an integra?
this is on a 97 integra type R.it should be the same as a gsr.when i say flywheel surface height i mean the distance between the place where the pressure plate sits and the actual surface the disc touches.i need to make sure that the machine shop surfaced it correctly.i have .112 inches on mine.
Old Feb 8, 2003 | 02:44 PM
non-VTEC's Avatar
Default Re: does anyone know flywheel surface height on an integra? (turbotypeR)
check the helms manual.......should tell you there
Old Feb 8, 2003 | 02:52 PM
25 Year Member
Default Re: does anyone know flywheel surface height on an integra? (non-VTEC)
helms manual does not say.it says to replace it.it never mentions surfacing it.i looked on act's web site and it says .108.i used a cheap caliper so it could be right.
Old Feb 9, 2003 | 02:51 PM
25 Year Member
surely someone knows!
See Are X
Feb 20, 2008 08:14 PM
BudMan
Mar 15, 2007 04:20 AM
yellowbuffalo
Jun 5, 2003 12:27 PM
Kataku2K3
Oct 11, 2002 09:49 AM
