Difference between 5 lug ITR and 4 lug ITR
Old Feb 9, 2003 | 03:43 PM
Skeletor's Avatar
Default Difference between 5 lug ITR and 4 lug ITR
Is there any? I didn't even know there were two kinds of ITR suspensions. I'm looking into a cheap upgrade of brakes and suspension for my 94 Civic DX. Does anyone know where I can find a list of differences in the SI, GSR, 5 lug ITR, and 4 lug ITR?
Old Feb 9, 2003 | 06:45 PM
Shawn C's Avatar
In The Garage
Default Re: Difference between 5 lug ITR and 4 lug ITR (C Rich)
the 5-lug is 5x100, the 4-lug is 90-02 accord 4-lug, 92-96 prelude 4-lug pattern (4x114 i think) the 4-lug has bigger brakes, and uses bigger axle ends. the 5-lug is cool, but the 4-lug is lighter and better IMO. it came on the USDM 97 ITRs (only 300 here in the states) and like 96-98? CTRs and pre-98 JDM ITRs also. this is all i know, sorry if its hard to understand, im tired.
Old Feb 9, 2003 | 06:52 PM
Skeletor's Avatar
Default Re: Difference between 5 lug ITR and 4 lug ITR (22lbGS-R)
I'm asking because I've seen the 4 lug cheaper than the five lug. Thanks for the input. Anyone else have more?
Old Feb 9, 2003 | 07:40 PM
eg6ajk's Avatar
4 lug = usless. brakes are size as GSR but with 4x114 spacing which sucks as far as wheel selection . it was found only on the 96-7 JDM ITR (not USDM or any other)
the price of the ITR 4 lug is higher then GSR which is more common as far as replacement parts and overall avalibility.
5 bolt gets larger brakes and in JDM ITR (larger axles - 36mm). again more cosmetic then anything for most.
GSR brakes with light weight wheels will set you lower then 5 bolt ITR
GSR get my vote as best set up for the money
Old Feb 9, 2003 | 07:49 PM
Skeletor's Avatar
Default Re: Difference between 5 lug ITR and 4 lug ITR (eg6ajk)
What's the difference in the GSR and SI? Smaller brakes?
Old Feb 10, 2003 | 01:07 PM
owen_the_soyboy's Avatar
smaller front calipers on the Civic Si/Ex, although they both share the same size rotors.
Old Feb 10, 2003 | 01:58 PM
sgT's Avatar
sgT
5 lug is 5x114
4 lug is 4x114
5 lug uses 11.1 front rotor and 10.2 rear
4 lug uses gsr size 10.2 front and 9.x rear
jdm itr 5 lug uses prelude 36mm outer joints as opposed to the 4 lug and usdm
5 lug 32mm
the larger brakes are better by far, but i would suggest getting the us itr because
it makes like easier because the axles are the same size
Old Feb 10, 2003 | 02:34 PM
Skeletor's Avatar
Default Re: Difference between 5 lug ITR and 4 lug ITR (sgT)
I think I'll go with the GSR package. It'll be a needed improvement over my tiny DX stoppers. Is 550 a decent price for the entire suspension?
Old Feb 10, 2003 | 05:48 PM
tinkerbell's Avatar
what about honda Odyessy 300mm 12 inch front discs?
do these have larger calipers too?
(sorry, a bit OT)
t..
Old Feb 10, 2003 | 05:53 PM
slomofo's Avatar
GDD Member
5 lug is also supposed to have better traction.
Old Feb 10, 2003 | 05:57 PM
b18bvtec4drteg's Avatar
Default Re: Difference between 5 lug ITR and 4 lug ITR (slomofo)
Please care to elaborate?? I find that BS. 5 lug or 4 lug does not have any effect on traction. LSD/ tires do.
Old Feb 11, 2003 | 07:39 AM
Shawn C's Avatar
In The Garage
Default Re: Difference between 5 lug ITR and 4 lug ITR (b18bvtec4drteg)
4 lug itrs WERE in the US in 97. if youre not sure, dont post it as a fact
Old Feb 11, 2003 | 09:31 AM
sgT's Avatar
sgT
Default Re: Difference between 5 lug ITR and 4 lug ITR (tinkerbell)
(sorry, a bit OT)
t..
if thats true, i would think they are related to the s2000 front brakes
sgT's Avatar
sgT
That is 100% false
Old Feb 11, 2003 | 08:22 PM
JOMO
Guest
Posts: n/a
you dont know how 5 lugs give you better traction?????????
BAN!!!!!!!!!!!!!!!!!!
perseverance
Jul 9, 2010 06:11 PM
polything
Sep 28, 2007 07:28 AM
Filliam H. Muffman
Mar 3, 2004 05:19 PM
S@nt0s
Dec 7, 2003 09:47 PM
Tuan
Dec 4, 2003 05:39 PM
