JG Edelbrock Throttle Body ?
Old Jan 24, 2004 | 01:11 PM
dpine's Avatar
Default JG Edelbrock Throttle Body ?
any one have experence with edelbrocks 65 mm Tb. List the pros and cons. any problems. I want to go with the edelbrock because of the fact it comes with a tps already set.
thanks
Old Jan 26, 2004 | 09:02 AM
Boofster's Avatar
Default Re: JG Edelbrock Throttle Body ? (dpine)
I just put a 65mm JG on my Skunk2 mani with the GSR swap. Fits great. Not sure if it works yet. Car won't idle so I can't say.
Old Jan 26, 2004 | 09:06 AM
92b16aTurbo's Avatar
Default Re: JG Edelbrock Throttle Body ? (Boofster)
I used a JG on my B18a. Fit great. It took a while to get though, as I didn't want to be out of a car for a week while they sent it to me (core exchange).
Old Jan 26, 2004 | 09:28 AM
dpine's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boofster &raquo;</TD></TR><TR><TD CLASS="quote">I just put a 65mm JG on my Skunk2 mani with the GSR swap. Fits great. Not sure if it works yet. Car won't idle so I can't say.</TD></TR></TABLE>
Idle problem caused from throttle body? tps? the reason why I ask is because I'm sick of trying to set my tps on my old tb. I have been through 3 tps's and set them correctly and I still throw a tps code.
Old Jan 26, 2004 | 01:00 PM
Boofster's Avatar
What do you mean set the TPS? You can't "set" it. I can't wait to go play with it after work
I capped off the TB vacuum on top so I think I need to run that to the EVAP. Might fix it. Air probably needs to come before the TB instead of after (duh!). Using vacuum distribution block with turbo gets you spoiled. I also need to check the IACV and clean it or even swap it out with my old one. Lots of stuff to check...
I blocked off the whole FITV section and bypassed the cooling system completely since I am in AZ. (https://honda-tech.com/zerothread?id=596485)
Old Jan 29, 2004 | 08:43 PM
accord91h22's Avatar
Yes you can set your tps. You have to take a multimeter to it and have it at a certain point. A haynes manual tells you how to do it.
Old Jan 29, 2004 | 09:21 PM
hondatim's Avatar
Default Re: JG Edelbrock Throttle Body ? (accord91h22)
TPS shouldn't need to be 'set' on stock throttle body. If TPS code, Honda recommends replacing sensor, which a lot of times means replacing TB.
As far as the JG Edelbrock TB goes, the only thing that I see on a semi consistent basis with these is that most seem to have a misadjusted throttle stop which holds throttle plate open too much at idle and caused high or erratic idle. easy to adjust though.
Just my 2 cents though...
Old Jan 30, 2004 | 01:08 AM
ALLMOTOR18's Avatar
Default Re: JG Edelbrock Throttle Body ? (hondatim)
the return spring seems to be too soft, not allowing the TB to close completely..
slowEGles
Apr 6, 2014 03:39 PM
trevek10
Mar 10, 2011 01:58 PM
dt4life
Apr 6, 2005 07:45 PM
tgh22a
Mar 19, 2005 03:43 PM
tgh22a
Mar 13, 2005 12:47 PM
