Gasket question
Old Jan 27, 2004 | 12:34 PM
Huee's Avatar
Default Gasket question
What gaskets and seals do you need to replace when having your motor rebuilt. Like for instance if i picked up a bare block and wanted to build it up. Aside from head gaskets and intake manifold and exhaust gaskets, what else would i need?
Old Jan 27, 2004 | 03:01 PM
gloryhog's Avatar
Default Re: Gasket question (Huee)
1-main bearings , 2- rod bearings , 3- front and rear crank seals, 4- cam seals, 5-oil pan gasket , 6- head gasket , 7- thermostat gasket , valve cover gasket,throttle body gasket , injector seals , thrust washer for crank, head bolts (opt.), throwout bearing for clutch, valve seals if doing valve job. I mite have missed one but thats it!!!!
97CTR
Apr 27, 2009 06:26 PM
Rikaro
Feb 28, 2008 10:07 AM
itr1235
Apr 11, 2007 08:02 PM
jbell
Jan 7, 2005 01:56 PM
Hans
Mar 11, 2003 06:19 AM
