Help! The end of my compression guage is stuck in the spark plug hole
Old Jun 15, 2004 | 06:05 AM
Teal95Coupe's Avatar
Default Help! The end of my compression gauge is stuck in the spark plug hole
I was attempting to do a compression check and when I pulled the gauge back out of the hole the end part didnt come back out with it. It unscrewed from the rest. My friend suggested I superglue the end that came back out to the part stuck in and try to unscrew it that way. Barring any better advice I will attempt that after being brought some super glue but is there any other way? I figure if I take the head off I will be able to get it out from the bottom but if possible I would like to avoid that.
Modified by Teal95Coupe at 4:08 PM 6/15/2004
Old Jun 15, 2004 | 07:23 AM
Ekasey's Avatar
Default Re: Help! The end of my compression gauge is stuck in the spark plug hole (Teal95Coupe)
try using a long set of pliers to unscrew, it depends how loose it is
Old Jun 15, 2004 | 07:59 AM
corso28's Avatar
my friend did this a while back while using mine. i told him to put a tiny bit of superglue on it wait 5 minutes then try. worked like a charm and the threads are still in good condition. try that. if that doesnt work, try loctite red. let sit for 24 hours. then unscrew
Old Jun 15, 2004 | 09:24 AM
Default Re: (corso28)
Thanks for the help. The superglue worked fine.
Luck6
24
Jun 13, 2015 04:50 PM
gjbraun
Jun 18, 2012 10:57 AM
Teg4e
Jun 29, 2006 02:24 PM
Anyotherone
Apr 14, 2003 08:37 PM
