need help with no start condition
Old Nov 25, 2013 | 09:29 AM
scott757's Avatar
Default need help with no start condition
my b18c motor has been bogging down lately so I replaced fuel filter , did oil change , new fuel pump , spark plugs and wires also replaced my grounds . after that it ran for a little (bogging less ) n when warm it would die at idle .. it would start with WOT but nothing else and it would still bog . I foubd a vacuum leak and replaced hose yet still same problem .. this leaves me to think the tps , brand new autozone remanufactured dizzy or map sensor bAd .. also the car won't start now and plugs are covered in fuel cranks but won't start
Old Nov 25, 2013 | 09:33 AM
Fliptard's Avatar
Default Re: need help with no start condition
check the mechanical timing.
Replace the plugs, wires, dizzy cap and rotor as well
Old Nov 25, 2013 | 09:44 AM
scott757's Avatar
I have timed the motor again this morning still to no avail waiting for cap and rotor to come in
Old Nov 25, 2013 | 09:47 AM
fcm's Avatar
fcm
Old Fart
Sounds like no spark, check coil and ICM. 94
Old Nov 27, 2013 | 11:20 AM
scott757's Avatar
could a bad icm or coil cause motor bogging at certain loads ? or would that be due to an improperly calibrated tps
Old Nov 27, 2013 | 11:21 AM
scott757's Avatar
got it started by sanding down terminals on rotor cap still bogs and only starts at wot
honda20crx
Apr 19, 2010 12:51 PM
Honda Sport
Jun 4, 2003 05:27 PM
Spoonin
May 29, 2003 07:23 PM
si00000
Nov 1, 2001 06:10 PM
96whitels
Aug 19, 2001 02:06 AM
