03 Pilot Power Steering pump removal
Old Nov 17, 2013 | 07:11 AM
rexabbot's Avatar
Default 03 Pilot Power Steering pump removal
How can I reach the nut underneath the pulley - nut #23 in the parts diagram?
http://www.hondapartssales.com/lisle...s=&view=normal
Thanks
Old Nov 17, 2013 | 07:20 AM
Jjbaehr's Avatar
Remove engine cover, you will need a deep 12mm socket, extension and ratchet. A deep socket will slide over the threads and grab the nut.
Old Nov 18, 2013 | 03:34 AM
rexabbot's Avatar
Default Re: 03 Pilot Power Steering pump removal
Thanks for the reply
I tried the deepwell both 3/8 and 1/2 drive and with a short extension.
They were too short by about 1/4 inch I could not get the ratchet on as it hit the pulley. And too long with the extension. The motor mount was in the way and put the ratchet at too much of an angle.
Maybe I need to try a different brand, I was using a Stanley black set?
Old Nov 18, 2013 | 03:55 AM
Jjbaehr's Avatar
Oh I thought you meant the other 23 nut, the adjusting nut. You meant the lower nut under the pulley. Either way I can get it off with a 3/8 craftsman ratchet and deep well 12mm socket. You will also have to loosen the adjusting nut to set the belt tension.
discgolfer
Aug 9, 2017 12:23 AM
miamatt
Feb 18, 2015 11:01 AM
wangbungal
Feb 22, 2013 04:18 PM
dsturch1
Sep 28, 2009 04:28 AM
B20LS-T
Mar 31, 2003 08:18 PM
