Rev Limiter on 96 Accord
Old Nov 27, 2013 | 07:10 PM
Loy's Avatar
Loy
Default Rev Limiter on 96 Accord
Does anyone know what the rev limiter is set to at the factory for a 96 Accord? It has a 2.2L with Vtec. It seems to be kicking in at 3,250 rpms. Is this correct? I thought the vtec doesn't kick in until you hit 5,000 rpm. I just did a timing belt job but I don't know if this happening before or not since I didn't get that high since it was over due for the timing belt.
Old Nov 28, 2013 | 01:26 AM
grjr's Avatar
Default Re: Rev Limiter on 96 Accord
automatic transmission and in neutral? the rev limiter is pretty low, but I don't remember exactly what RPM it is set at. Are you driving down the road?
Old Nov 28, 2013 | 07:04 AM
Loy's Avatar
Loy
It's a 5 speed manual and it was doing it both while I was driving and while I was reving the motor just sitting in the garage.
Old Nov 28, 2013 | 10:48 PM
grjr's Avatar
It didn't have this problem before you changed the timing belt? Since you just replaced the timing belt you probably want to recheck your cam/crank timing. If your timing is off then your engine will run poorly and be low on power.
Old Nov 29, 2013 | 05:17 PM
Loy's Avatar
Loy
If it was the timing wouldn't it effect the performance of the engine throughout the entire rpm range and not just once it hits a certain rpm? The engine seems to be running perfectly while it ideling even better then when I first got the car.
Old Nov 30, 2013 | 07:33 AM
fcm's Avatar
fcm
Old Fart
As mentioned, recheck the valve timing. 94
Old Apr 14, 2014 | 05:57 PM
Loy's Avatar
Loy
Ok so I finally got around to recycling my timing and it is so I on. Any other suggestions?
93accordf22a
Dec 22, 2020 04:58 AM
professorman
Nov 25, 2014 11:28 AM
casper.hughes
May 19, 2008 08:38 PM
garrett_j17
Jan 28, 2007 09:28 AM
exhaust
Nov 17, 2001 04:40 PM
