Minus transmission
Old Nov 2, 2013 | 06:15 PM
Upthecreek's Avatar
Default Minus transmission
Gentlemen I am new to this forum so please have a little patience with me. I am in the process of doing an engine swap. The donor is an 04 Accord V6 automatic. The recipient is a soon to be built Airboat. The engine will be installed pretty much as it came out of the car less transmission. I have all of the wiring diagrams and will use original ECM. My question : is all the sensor wiring from the transmission back to the ECM necessary for proper engine operation or can it be eliminated. I can duplicate the pressure and temperature sensor signals ,but what about the mainshaft and output shaft sensors on the transmission.
Old Nov 2, 2013 | 06:31 PM
F22Master's Avatar
Default Re: Minus transmission
You could try finding a manual ECU.
Old Nov 2, 2013 | 06:52 PM
Upthecreek's Avatar
If I am not mistaken I think the manual transmission has mainshaft and output shaft sensors also
Old Nov 2, 2013 | 07:14 PM
F22Master's Avatar
That may be true, but that's like still like 10 less things it's going to be throwing codes for.
Old Nov 3, 2013 | 03:36 AM
Upthecreek's Avatar
Yep. Good point.
John Shotton
Jan 6, 2019 10:12 AM
Jimmy21
Mar 2, 2017 04:55 PM
cartopics
Jun 7, 2012 09:33 AM
SuperDuude
Aug 6, 2004 02:15 PM
carolinaACCORD
Aug 18, 2001 02:37 PM
