honda civic overheating
Old Oct 28, 2013 | 03:17 PM
hondafan89's Avatar
Default honda civic overheating
Hey so I have a 89 Honda civic dx hatch, 1.5L with an overheating problem and the heater has stopped working. ive replaced the thermostat, and the water pump, ive flushed out my radiator and its still overheating relatively fast. theres no white smoke coming out of the exhaust pipe to indicate that is a blown head gasket but im still not sure, any ideas on what it could be?
Old Oct 29, 2013 | 05:42 AM
KYLEEFinG's Avatar
Is your fan working?
Old Nov 3, 2013 | 11:35 PM
hondafan89's Avatar
Default Re: honda civic overheating
Yeah it is.
Old Nov 4, 2013 | 04:11 PM
midwest aaron's Avatar
did you bleed the cooling system? is the fan rotating in the right direction? the fact that you say the heater stopped working tells me you are low on coolant.
Old Nov 4, 2013 | 04:47 PM
fcm's Avatar
fcm
Old Fart
X2 low coolant and/or air in the system, bleed it. 94
Old Nov 11, 2013 | 03:59 PM
Ej1coupe3's Avatar
try bleeding the coolant system like midwest said but my friend had the d15 and same problems as you and it was blown head gasket i would try that after all its a couple of bolts and gaskets rock auto sells a gasket set(the head gasket and up) for like 60 + shipping make sure all the blots are torqued to the right specs and you got all new gaskets if worst case
Old Nov 11, 2013 | 07:32 PM
10psiLsEf2's Avatar
Heater not blowing is either a huge air bubble in system,clogged heater core,or a restriction in the coolant passages.
Id say air pocket
Old Nov 11, 2013 | 07:53 PM
slowDB7's Avatar
overheating and no heat coming out of the heater is usually from bad waterpump or theres air trapped in your system
Old Nov 11, 2013 | 11:08 PM
ricebike's Avatar
after you are sure that you burped the system & know that the water is flowing (confirming a good pump)...
it can be also a bad t-stat from the box... bypass it by removing it temporarily
how's the condition of the rad? i know i had to replace mines 2x already due to the area i'm at (good thing i have a lifetime warranty on that radiator)
Old Nov 13, 2013 | 01:16 PM
DAAPDC2's Avatar
Check all coolant hoes for pin hole leaks.
Air pockets and faulty T-stats are common.
GSD
Honda CR-V & Element
Oct 29, 2017 04:33 PM
Zer0_
Mar 23, 2015 07:55 PM
rajah99
11
Jan 23, 2012 09:49 AM
Bobby808
Apr 27, 2005 11:22 AM
extrmeboost
Jul 15, 2003 07:42 AM
