Idle problem.
Old Oct 19, 2013 | 05:44 PM
Jmx305's Avatar
Default Idle problem.
Hey guys was having some awful idle problems not long ago. I change my idle air control valve and my idle got better but not perfect. If I give the car gas when the car is in neutral once the rmps start dropping it'll stay at 1 1/2 for like 2 secs and it'll go back to normal or it'll drop to normal go back up and come back to normal and it'll idle fine after that. It's a 93 hatch with a b18c Japanese type r. I replace the iac valve and pcv valve and all my hoses are hooked up and in good conditions. Any ideas on why it does that?
Old Oct 20, 2013 | 03:15 PM
Jmx305's Avatar
Default Re: Idle problem.
Bump
Old Oct 23, 2013 | 08:40 PM
Jmx305's Avatar
Old Oct 24, 2013 | 02:40 PM
preludeNApower's Avatar
Maybe a small vac leak. Unplug your iacv and see if it still does it.
Old Oct 24, 2013 | 11:29 PM
supertace91's Avatar
check your spark plugs,clean the throttle body really good, maybe some loose screws or bolts, bleed your coolant...loose hoses maybe.
Old Oct 25, 2013 | 12:45 AM
holmesnmanny's Avatar
could be as simple as a bad oxygen sensor...they don't always throw codes...especially on obd1 cars
always go Densor on oxygen sensors
averyvm
17
Jan 17, 2007 11:51 AM
hondachris1994
Mar 3, 2006 06:49 AM
90AcuraIntegra04
Dec 11, 2005 05:26 PM
CRX-SIR
Sep 20, 2004 06:00 PM
s2k
Feb 25, 2003 06:50 PM
